wiring help
Old Apr 21, 2008 | 07:52 AM
(760)doogie's Avatar
Default wiring help
hey so im basicaly done with poor mans r swap in my 91 si, but i need a lil bit of help with some wiring. i got a new engine harness because the last one was all cut up, but i have 2 questions. where does this plug go
and where do the yel, grn/blk, and wht wires go
Modified by (760)doogie at 8:57 AM 4/21/2008
Modified by (760)doogie at 9:01 AM 4/21/2008
Old Apr 21, 2008 | 08:00 AM
jlicrx's Avatar
Default Re: wiring help ((760)doogie)
no pictures?
the green/black and yellow are probably for the back-up light switch on the transmission - if the white is right next to the green/black and yellow, it would be O2 sensor
Old Apr 21, 2008 | 08:06 AM
jlicrx's Avatar
the plugs in the bottom picture - white plug connects to chassis harness at driver's side at firewall - green plug goes to injector resistor box
Old Apr 21, 2008 | 08:38 AM
Default Re: wiring help (jlicrx)
so the white plug is somewhere inside the cabin on the drivers side by the firewall. i thought the black wire went to the o2 sensor
Old Apr 21, 2008 | 09:08 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie &raquo;</TD></TR><TR><TD CLASS="quote"> i thought the black wire went to the o2 sensor</TD></TR></TABLE>the O2 sensor itself has a black wire, but the wire in the harness is white
Old Apr 21, 2008 | 09:09 AM
jlicrx's Avatar
what is the model of your car?
edit: sorry, didn't see it was Si
Modified by jlicrx at 11:17 AM 4/21/2008
Old Apr 21, 2008 | 09:21 AM
91blackEF's Avatar
ur last picture the lagrer plug goes to the windsheild wiper motor and the other green one goes to the thing mounted onto your firewall right behind the motor sorry i dont know the name of what it is or wtf it does i just know where it is lol
Old Apr 21, 2008 | 10:47 AM
kirbyman's Avatar
Default Re: wiring help (91blackEF)
heres where those plugs go.
Old Apr 21, 2008 | 10:49 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91blackEF &raquo;</TD></TR><TR><TD CLASS="quote">ur last picture the lagrer plug goes to the windsheild wiper motor and the other green one goes to the thing mounted onto your firewall right behind the motor sorry i dont know the name of what it is or wtf it does i just know where it is lol </TD></TR></TABLE>not true - the wiper motor connector is on the chassis harness, not on the engine harness - it is a male plug which goes into the female connector on the wiper motor
Old Apr 21, 2008 | 11:48 AM
huh, well i pulled all my wiring through the firewall so i gotta find that plug. so what is the black wire for?
Old Apr 21, 2008 | 12:08 PM
kirbyman's Avatar
whats on the end of it?
Old Apr 21, 2008 | 12:51 PM
Default Re: wiring help (kirbyman)
i think its just cut but ill check it when i get home
Old Apr 21, 2008 | 01:13 PM
jlicrx's Avatar
peel back the harness covering a ways and see where the black goes - the O2 sensor wire is shielded and the ground for the shield is a black wire - could be
Old Apr 21, 2008 | 03:08 PM
well i cant find that plug thats supposed to be on the drivers side, where do the wires for that plug go?
Old Apr 22, 2008 | 06:55 AM
jlicrx's Avatar
to the ECU
Iron_Forrix
Dec 30, 2006 09:32 AM
JeDiMaster
Aug 9, 2006 09:51 PM
SiBuddy00
Jul 6, 2005 11:51 AM
Jonathan_ED3
Apr 23, 2003 12:54 PM
