Eagle rods won't clear the main girdle on DOHC ZC. I can't notch the girdle enough...
Old Apr 21, 2008 | 06:39 AM
I8ayellowcrayon's Avatar
Default Eagle rods won't clear the main girdle on DOHC ZC. I can't notch the girdle enough...
Has anyone successfully installed a set of Eagle H beam rods (with the new "2000" bolts) on an OBD0 DOHC ZC???
I notched the cylinder walls, no problems there. But I have installed a rod, and turned the crank and it hits the main girdle hardcore. The bolt is almost flush with the outside of the girdle when it hits. There isn't even 1/32" between the rod and the edge of the girdle...
There is no notching to this, all I can think to do would be to cut a damn hole in the girdle for the rod to clear, and weld up some sort of support thing OVER the hole to clear the rod.
BAAAAAHHHHHHH! Why can't people make a part that fits???
I'll try to get some pics on here later for more clarification...
Old Apr 21, 2008 | 06:52 AM
So uhhh.... I notched the hell out of the girdle, but it fits...
Gay.
Old Sep 10, 2008 | 05:42 PM
jtmoney2002's Avatar
Default Re: (I8ayellowcrayon)
Was putting my dohc zc together tonight running into the same problem, kinda scared ill hit the oil jacket deal tho in the one spot
Old Sep 11, 2008 | 01:48 PM
LastGenEK's Avatar
Default Re: (jtmoney2002)
Pics?.....
Is it the rod bolt or the rod itself?
Iv heard that tunertoyz rods fit D16's sohc but im not sure about ZC's
Modified by LastGenEK at 3:06 PM 9/11/2008
Old Sep 11, 2008 | 05:04 PM
Default Re: (LastGenEK)
Ive did a lil bit more looking around and u have to notch the girdle if u use the arp 2000 bolts in the eagle rods unless u have a custom girdle then get the whole things matched up and bored. so its alot easier just to notch it no pics ,but the rod bolts come right up to the middle of the girdle
Old Sep 11, 2008 | 05:06 PM
just have to notch it for the bolt,, alot of other d series motors have the same problem, with the eagle, arp 200 combo
bigddallas1993
Apr 24, 2008 08:32 PM
cbrodac0424
13
Aug 6, 2004 07:46 PM
Ronin Panda
Jun 1, 2003 02:02 PM
Ronin Panda
May 29, 2003 06:33 AM
