Help Misfire and Vtec not Poppin
i have a 99 civic ex with a b16a2 motor in it. Motor is all stock nothing is modified.
the car is throwing a p1399 (misfire code) i did a search and i changed out my whole dizzy , injector , spark plug , and wires still the light blinks. The check engine light will stay solid until i hit 3k rpm and then it will start blinking. Car run good . does not idle rough it run like there noting wrong with it. My vtec is not kickin in eitha i was thinking maybe it not kickin in because of the check engine light is on. I need Help!!!
Cool Cool Island Breezes. BOY-EE
Could be stuck open or leaky injector or something else that's causing big amounts of unburned fuel to get into your exhaust stream.
The CEL blinks when the ECU detects a misfire and an overly rich condition in the secondary O2 sensor. It blinks when the cat is in trouble, basically.
i just replaced all 4 injectors so i know it not the injectors.i heard the crank sensor would throw a misfire code if it out. but we checked it and it still good .
replace the whole dizzy. still the same problem. car run great doh! previous owner said he change the spark plugs and wires. but imma change it out tomorrow and get the motor timed.
89eFRACER
12
Apr 13, 2006 09:21 PM
H22AEG2
Jun 9, 2005 06:09 PM
