recommended valve size for built tubo lsvtec setup
Old Apr 21, 2008 | 06:23 AM
TEAM DRAG's Avatar
Default recommended valve size for built tubo lsvtec setup
ok guys im in the market for valves,now im doing a built lsvtec setup and im shooting for 450's pump and 550's racegas.now i just want to know what size valves would be preferred for a setup of this size and power thanx h-t.
Old Apr 21, 2008 | 06:57 AM
blackeg's Avatar
Default Re: recommended valve size for built tubo lsvtec setup (TEAM DRAG)
you could use oem. i spent last year making low 400s with stock valves, and will be using them again this year. your machinist should be able to check them over and make sure they are ok before you use them
iakona
Mar 11, 2005 12:37 PM
newdrifter5
Sep 7, 2004 05:29 PM
