driver side window wont roll completely up!!
Old Apr 21, 2008 | 06:04 AM
stevew84's Avatar
Banned
Default driver side window wont roll completely up!!
got a 97 ek and the window will only go up about 2/3 of the way. the weather stipping inside the window frame some how was bunched up at the sideview mirror and i cant straighten it out. i have searched for this but everyone has a damn EG. anyways i need to put the window back on track (if its off) or just loosen up the weather stripping so the damn thing will go up all the way. if anyone has a write up please post.
pics would help
thanks
Old Apr 21, 2008 | 07:28 AM
eskimo10's Avatar
https://honda-tech.com/zerothread?id=2061336
thats a good thread dealing with this same problem.
Also I'm not quite sure what you meant by weather stripping being bunched, a pic would be very helpful.
Old Apr 21, 2008 | 08:43 PM
TheDamnedOne's Avatar
Default Re: driver side window wont roll completely up!! (stevew84)
well to unbunch that strip you are goin to have to take ur door panel off and also the weather insulator. afterwards u will need to lower ur window all the way down and take it off track. to take it off track u will have to loosen or remove the bolt that is located near the bottom wehre the door speaker is located. after u got it off the track, reach inside ur door and pull down the stripping with a pair of needle nose plisers.. that should solve ur problem. then reconnect everything u had taken off.
mine has done that to me a time or two
-good luck-
Old Apr 21, 2008 | 08:47 PM
stupidguy10's Avatar
welcome to the world of hondas
Old Apr 21, 2008 | 11:10 PM
vikboii's Avatar
lol werd
laoboisosilly
Jun 3, 2009 02:14 PM
deerman2701
Nov 27, 2007 05:59 AM
i-want-a-crx
Oct 13, 2007 08:41 AM
EnKidu
Oct 10, 2004 06:43 PM
Agent Zero
Aug 13, 2004 01:53 PM
