starter issue?
Old Apr 20, 2008 | 08:39 PM
eskerley's Avatar
Default starter issue?
i was installing A/C lines into my civic and after i finished i went to start the car and it made a grinding sound after it started, turned the car off and tried to start it again, it wounld start. I push started it and it srarted up. After that it only started about 4 times and every time it started it made a grinding noise. Now it wont start again.
know when i go to strt it the starter makes a clicking and whining noise.
Does this mean i need a new starter?
Modified by eskerley at 4:18 PM 4/21/2008
Old Apr 21, 2008 | 03:20 PM
eskerley's Avatar
Default Re: starter issue? (eskerley)
ne ideas?
Old Apr 21, 2008 | 03:24 PM
mike03,95civic's Avatar
I had the same problem. it ended up one of the conections was loose. i also changed the cap and rotor in the distributor.
Old Apr 21, 2008 | 03:29 PM
eskerley's Avatar
Default Re: starter issue? (mike03,95civic)
all the connections are fine and the car runs fine just wont start; since i can get it to start it i push start it.
Old Apr 21, 2008 | 03:37 PM
i hear you can take your starter out and take it to like pep boys or autozone and they can test it for free.
Old Apr 21, 2008 | 07:51 PM
eskerley's Avatar
I will try that. thanks
Old Apr 21, 2008 | 08:01 PM
EG2Driver's Avatar
check your ground on from the transmission to the chassis. Mine was cut from corrosion, so it would not start, but it still ran.
prelude2001h22a
Nov 22, 2014 02:04 PM
civicbro
Feb 19, 2004 02:47 AM
fsck3r
10
Aug 5, 2003 05:43 PM
94si94cx
Jul 28, 2003 09:37 AM
lilcasino
Jul 15, 2002 01:23 PM
