over reved my sohc (bent or dropped valve?)
Old Apr 20, 2008 | 08:07 PM
purple95's Avatar
Default over reved my sohc (bent or dropped valve?)
Whats up every body! Im in need of some help here, maybee some one could lead me in the right direction. I have a jdm d15 vtec obd1 swap in my 91 hatch. Saturday night, I was racing a crx si, had to shift from third to fourth but i ACCIDENTLY shifted into second . The car sounded like it was running ok until I came up to a light, I had to give it gas to keep it running. I pulled over and sounded like it was iddeling really low.
Turned it off then wouldnt start any more. wasnt getting spark. So changed the coil and started up but sounded the same. pulled the wires and noticed one cylinder wasnt reacting from pulling the wire off. Also pulled off the fuel rail with injectors to check for fuel and they all were fiering.
What do you guys think?
-Spun bearing
-floated valve
-other
Any suggestions please.
Old Apr 20, 2008 | 08:27 PM
purple95's Avatar
Also inspected the plug, looked ok.
Old Apr 20, 2008 | 08:55 PM
highroller54's Avatar
Default Re: (purple95)
compression test time, sounds like you bent a valve.
Old Apr 20, 2008 | 08:59 PM
purple95's Avatar
Default Re: (highroller54)
If I pull the head off would I be able to tell if valve is bent?
Thanks man
Old Apr 20, 2008 | 09:30 PM
Bob_760's Avatar
yes
Old Apr 21, 2008 | 03:49 AM
purple95's Avatar
Default Re: (Bob_760)
How much would it be to repair the head.
Old Apr 21, 2008 | 06:48 AM
purple95's Avatar
Any other suggestions or advice?
Old Apr 21, 2008 | 08:11 AM
Tippyman's Avatar
Before you go yanking the motor apart, do a simple leakdown test. It will tell you where the problem is likely located before you tear **** up unnecessarily.
Old Apr 21, 2008 | 10:24 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Tippyman)
ah, 3-2 isn't that bad.. my favorite is the cataclysmic 5-2 downshift.
Old Apr 21, 2008 | 11:19 AM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Before you go yanking the motor apart, do a simple leakdown test. It will tell you where the problem is likely located before you tear **** up unnecessarily.
X2
As for cost of repairing the head (If thats the problem) its VERY specific to exactly what happened, the head might be ok, might be cheap to fix, might be expensive to fix, or it might be trash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">ah, 3-2 isn't that bad.. my favorite is the cataclysmic 5-2 downshift.</TD></TR></TABLE>
I prefer the 6-1 K liquifier
Old Apr 21, 2008 | 12:11 PM
sanimalp's Avatar
$cat /dev/urandom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">
I prefer the 6-1 K liquifier </TD></TR></TABLE>
lol
Old Apr 23, 2008 | 11:52 AM
purple95's Avatar
Default Re: (sanimalp)
What's up guys. Got the news on the head. We pulled the head off and took it to a machine shop. They took it apart, looked at it and pressure tested it, they said all the exhaust valves were bad. I'm having them rebuild it. I'm thinking of just using oem parts and dropping in a aftermarket cam. Any suggestions on the cam or about the head before its to late. Thanks for the responses everybody.
Old Apr 23, 2008 | 11:57 AM
purple95's Avatar
Also saw my timming was off.
Old Apr 23, 2008 | 12:36 PM
steveo123's Avatar
how much is this head work costing you? if its more than 200 bucks i would just go buy another d15b for 300 bucks at your local import shop. its gonna cost way more after a new head gasket, new head studs.
Jake Pierson
Nov 24, 2018 07:53 PM
MeGotRoundEye
Honda CR-V & Element
Apr 27, 2012 09:44 AM
netfreak
23
Jun 20, 2011 10:34 AM
dhatcher2002
Nov 25, 2008 10:26 AM
Schaz
Nov 7, 2004 09:06 PM
