Can this be fixed?
On my 2001 Accord (4 cyl, auto) I just noticed a bolt has sheared off that helps hold down the passenger motor mount. Is this stud something that can be unscrewed from the transmission and a new one put in its place, or are we talking about having to weld something back on in its place. Basically is this a hard fix or an easy fix...I'm open to other suggestions as well.
Pic at: http://www.flickr.com/photos/2...10537/
Thanks,
-Brent
Thanks,
-Brent
Actually I just solved my own question...I found the part listed an at OEM honda part website..it is a threaded stud, so All i need to do is remove it and install a new one...apparently honda was smart enough to realize these do break from time to time.
Thanks,
-Brent
Thanks,
-Brent
I'm not sure if these are the official Honda part numbers, but according to the online OEM honda supplier I found...
34398 Bolt, Stud (10x55)
34099 Nut, Flange (10MM)
Thanks,
-Brent
Thanks,
-Brent
