5W-30 or 10W-30
Old Apr 20, 2008 | 04:25 PM
Importn2oRacer's Avatar
Default 5W-30 or 10W-30
What oil is recommended or preferably better for a 6th gen accord with approximately 105,000 miles 5W-30 or 10W-30?
Old Apr 20, 2008 | 06:58 PM
TheMuffinMan's Avatar
He knows where you live!
What's the oil cap say...
Or the owners manual....
Old Apr 20, 2008 | 08:01 PM
FunnyVictor86's Avatar
Default Re: (TheMuffinMan)
oil cap should say 5W-30 ...
Old Apr 20, 2008 | 08:03 PM
Default Re: (FunnyVictor86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunnyVictor86 &raquo;</TD></TR><TR><TD CLASS="quote">oil cap should say 5W-30 ... </TD></TR></TABLE>
Exactly my point.....
Old Apr 20, 2008 | 08:51 PM
SuShiBoiiii's Avatar
Virtually all new passenger vehicles sold in the U.S. use either 5W30 or 10W30 oil. The difference between the two is that the 5W30 flows better when cold, so if you live in a cold climate or operate your vehicle in a cold climate during the winter months, you should use 5W30 if it is the preferred oil for your vehicle. If you live in a sub-tropical climate and don't operate your vehicle in cold climates, then 10W30 is acceptable as long as the manufacturer specifies that it is permissible to use it.
been using 10w-30 and havent had any problems
Old Apr 20, 2008 | 09:31 PM
The-Kid's Avatar
Default Re: (SuShiBoiiii)
Hmmmm weird. My cap actually says 5W-20 on my 01 Accord with ULEV. Hmmmmmmmmm........................................ .......... But I've been running 5w-30. Runs just fine.
Old Apr 20, 2008 | 09:42 PM
Default Re: (The-Kid)
i also have a 01 ulev vtec accord and i also run it on 5w-30 w/ no problems ... but best bet is to just run whatever the oil cap says unless your car is burning oil ...
Old Apr 21, 2008 | 03:21 AM
GhostAccord's Avatar
6th gen accords use 5w20 oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">Virtually all new passenger vehicles sold in the U.S. use either 5W30 or 10W30 oil.</TD></TR></TABLE>
3 out of 5 vehicles that i checked this morning use 5w20.
02 Accord / 04 RSX / 01 Tribute all use 5w20
96 Sunfire / 04 Grand Am Both use 5w30
Old Apr 21, 2008 | 05:19 AM
All newer Hondas use 5w20
My family's:
03 Pilot
01 Odyssey
06 Civic
Neighbor's
01 Accord
06 Accord
Are all 5w20
Old Apr 21, 2008 | 10:35 AM
not sure just copied that from some site i SEARCHEd for but yeah all newer honda 5w20 but been using 5w30 in all my newer honda and 10w30 on mine and my 3rd gen lol
Old Apr 21, 2008 | 07:26 PM
Alright cool. Yea I live in Florida so you don't get much of a winter down here and I've been using 10W-30. Thanks for the replies.
Old Apr 21, 2008 | 10:26 PM
YeuEmMaiMai's Avatar
didn't honda recently change the specs for a lot of their cars from the original specs?
I know acura puts in a lighter oil than what the manual calls for........seems to work just fine
Old Apr 22, 2008 | 11:23 AM
drksi99's Avatar
Default Re: 5W-30 or 10W-30 (Importn2oRacer)
start introducing 10w30 as it's nearing high mileage
don't listen to the smartass on here who said use what the oil cap says
yea the oil cap says 5w30 but you won't use that once ur car has 150 000 miles on it or else u can kiss it goodbye
engines with more miles require a higher viscosity in oil...im a mechanic i know
Old Apr 22, 2008 | 12:52 PM
Default Re: 5W-30 or 10W-30 (drksi99)
My 96 Accord with over 380,000km worked great and had no oil pressure or heating problems using light weight oil (AMSOil 0w30). What oil you use depends on what your oil pressure and temps look like not how old your engine is or how many km/miles are on it.
My car was dealer maintained before I bought it and I never missed an oil change. I think that has a lot to do with how much your engine wears as well. I've got the engine torn down right now and I measured the old bearing clearances for shytes and giggles and they are still well within spec. That would mean that I should still be using the spec oil right? Minimal change in bearing clearance = no change in oil......
Modified by GhostAccord at 6:00 PM 4/22/2008
Old Apr 22, 2008 | 02:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drksi99 &raquo;</TD></TR><TR><TD CLASS="quote">start introducing 10w30 as it's nearing high mileage
engines with more miles require a higher viscosity in oil...im a mechanic i know</TD></TR></TABLE>
Yeah I'm the smart ***.....
Owner's Manual: 5w30
Oil Cap: 5w30
Go to a dealership: 5w30
etc
If you're a mechanic then I'm sure you know the "high mileage" oil causes gaskets and what not to swell up to stop/prevent leaks, this can be bad for a motor that is running fine. Assuming the motor has no problems, there's no reason to change from dino to synthetic or change the oil's weight.
AND for your information my Accord has 209000 miles and seems to be running quite cherry with 5w30 dino, and my other accord has 160000 miles and is running just the same using 5w30 at regular intervals.
Old Apr 22, 2008 | 04:09 PM
what do you consider high milage?
honda engines can easily go 500K+ so 150K is not high milage for a honda
Old Apr 22, 2008 | 04:49 PM
CD_Ridge's Avatar
19 years of operation and 252,000+ miles on my Accord says 5W-30 is the right oil.
Old Apr 22, 2008 | 06:57 PM
Default Re: (CD_Ridge)
i guess you can run 10w-30 if you want on 150,000+ milage ... but its not really necessary ...
adrenalynmike
Honda Civic (2006 - 2015)
Oct 6, 2008 11:51 AM
TYPERman2001
Mar 7, 2007 08:32 PM
ck123
Jul 3, 2006 07:06 AM
EM2Civic
Mar 4, 2005 11:21 AM
macdaddy
May 9, 2002 06:09 AM
