@@@ code 17. (vss) @@@
Old Apr 20, 2008 | 04:05 PM
viciousef9's Avatar
Default @@@ code 17. (vss) @@@
ok this saturday i had a friend put in my alarm (wrx sti killer). my battery died and it would charge. it was my alternator. Everything was fine until i started to drive. check engine light. when i got to my other homies house (fourthgenb17a) we went over the problem. unplugged the cluster again and re-plugged the cluster and cleared the ecu. went and drove it again and there was the check engine light again. my friend told me he think the cluster is bad and to just get a new one from the junk yard. but to first check someone elses cluster in my car to see if it was the problem. so before i go to the junk yard and do all that does anyone have an idea of what it could be? thanks
Modified by viciousef9 at 8:53 PM 4/21/2008
Old Apr 20, 2008 | 04:15 PM
viciousef9's Avatar
oh yeah my tach and speedo both still work.
Old Apr 20, 2008 | 04:53 PM
D16SiHatch's Avatar
Default Re: (viciousef9)
is your tach lead going back to the ecu hooked up? it will throw a code if the computer isn't able to register your speed
Old Apr 20, 2008 | 06:54 PM
viciousef9's Avatar
im not sure. but i dont think that would be the problem. i have nt had this problem until i got my alarm installed saturday.
Old Apr 20, 2008 | 07:19 PM
viciousef9's Avatar
alternator and vss being the problems
Old Apr 21, 2008 | 11:28 AM
CANYONSTAR's Avatar
the samething happened to me.... its your speedometer cable it cost me like 5bucks at the junk yard...but its hard to find one...i found mine at pick your parts in wilmington off of blinn.
Old Apr 21, 2008 | 07:52 PM
viciousef9's Avatar
i went to pick a part today and bought a new cluster for 50 dollars. came home and swapped it out. cleared the codes and everything was fine. so i haven't had any problems other than my idle be a little weird when i come to a stop.
JustEFit
Aug 12, 2013 09:17 AM
_EF9
Apr 21, 2013 09:59 AM
h22_crx
Jul 16, 2008 07:07 PM
red-eg6
Jul 5, 2005 08:26 PM
Mach69
Jun 3, 2005 06:50 PM
