NEED HELP? SKUNK 2 PRO-C
i need help trying to lower my car? just when i thought every thing was going ok i came across a big issue. i first took out my skunk 2 pro-c's and i started with my front suspension, as i installed them i was going to adjust the preload of the shock to see my prefered ride height. so as i lowered the preload down, and by compressing the spring up, i thought it would lower my car by having a compressed full coilover, so when i lowered my car it looked stock height. does any one no what im doing wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoto »</TD></TR><TR><TD CLASS="quote"> does any one no what im doing wrong.</TD></TR></TABLE>
try using spell check and punctuation
you need to slam it down on the coliover threads not up, your coilover sleeve will look loose on the shock when the cars jacked up but will compress when you lower it down. you should be slammed.
SickAssLy
20
Dec 13, 2006 10:20 PM
