SiR hubs... moreover...
Old Apr 20, 2008 | 08:29 AM
EFstyle's Avatar
Default SiR hubs... moreover...
Alright so from what I understand if I put SiR hubs on my 91 civic Si... I wont be able to adjust the toe out far enough due to longer inner tie rod ends... BUT if i take off the outer tie rod ends, Cut the inner tie rod ends in about 1-2cm and run a die on it to clean up the threads again it will work 100% fine?? i just want to get this all cleared up befor I buy some hubs because this seems to be a very vague and confusing topic... nobody seems to know EXACTILY what you have to do...
Old Apr 20, 2008 | 08:57 AM
grog's Avatar
Default Re: SiR hubs... moreover... (EFstyle)
i have a question for you, are you getting the hubs for a front brake upgrade?
If so have you considered the EX knuckles? they're harder to find but dont require any mods.
and again heres a link (you probably wont find any more detailed write up's than this) look at the
section labeled: RUNNING JDM SiR KNUCLES ON N.AMERICAN 89-91 CIVIC/CRX
http://www.angelfire.com/ca/DrOhm/SiRkuckles.html
Old Apr 20, 2008 | 09:02 AM
EFstyle's Avatar
Default Re: SiR hubs... moreover... (grog)
yea most of it is for the up-graded brakes... and if i could find ex knuckles i would totally go for em but if all you have to do it just cut the inner tie rod ends a little bit then ill just get the SiR hubs... both of them have the best geometry for the car (better then DA) but i just wana make sure thats ALL i have to do! i read this link over a couple of times but im just trying to make sure i can run my outer tie rod ends just as they are and just cut the inner for more adjustablility... that link says sumthing about making more threads but idk if i have to do that or not
Old Apr 20, 2008 | 09:04 AM
Crx Jimmy's Avatar
the easiest thing would be to get sir tie rod ends, where did you get the spindles? usually they come from a front cut of a car that was shipped over do they not have the tie rod ends at the place you got the spindles?
Old Apr 20, 2008 | 09:11 AM
EFstyle's Avatar
Default Re: SiR hubs... moreover... (Crx Jimmy)
those would be kinda hard to get hands on wouldnt they? cause im looking to get all new stuff and finding brand new SiR tie rods would be hard... I got em from a guy that got em from PW:JDM
Old Apr 20, 2008 | 09:14 AM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">the easiest thing would be to get sir tie rod ends</TD></TR></TABLE>
NO thats what makes this so hard, They seem impossible to find new.
Old Apr 20, 2008 | 09:28 AM
EFstyle's Avatar
looks like cutting the inner tie rod ends 1 cm would do it... and that seems easy enough to me! so ill just get oem Honda inners,outers,ball joints, and wheels bearings just to do everything right the first time!! BUT another questions... would going to advance auto parts and getting Re-Man'd DA GSR Calipers be a good or bad idea?
Modified by EFstyle at 10:42 AM 4/20/2008
Old Apr 20, 2008 | 10:26 AM
richmond's Avatar
get something man'd by nissin, bap geon sells nissin brake stuff.
Old Apr 20, 2008 | 03:13 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">
NO thats what makes this so hard, They seem impossible to find new. </TD></TR></TABLE>
they arent discontinued, edm or jdm ones will work. No one has any relatives in Europe that could take a drive to honda and ship them over? or better yet call a honda dealer in Australia or UK they speak english. explain the situation and Im sure they would ship the products. doesnt seem that hard. Just sell the spindles and get some da or ex ones seems much easier
Old Apr 21, 2008 | 06:34 PM
EFstyle's Avatar
alright so basically SiR hubs with usdm inner and outer tie rod ends (outers screwed onto inners as far as they can go)... the front wheels will still look kinda like this / \ ? so you have to cut some thread off the inners so you can thread on the outers a little to get l l ? im just tryng to get a feel for why you have to cut threads... thanks
Old Apr 22, 2008 | 04:52 PM
EFSiR's Avatar
I have SiR knuckles on my 89 Si hatch. no problems with using domestic outer & inner tie rod ends.
With the alignment, your steering wheel will be slightly off. check FAQ for the link to my web site.
HTH
Old Apr 22, 2008 | 07:57 PM
EFstyle's Avatar
Default Re: (EFSiR)
I read all the info on the page you made and it says you have to cut the inner tie rods about 1 cm shorter... so you didnt do this?
Old Apr 22, 2008 | 11:58 PM
Tyson's Avatar
Default Re: (EFstyle)
i have ex knuckles for sale.
Old Apr 23, 2008 | 12:40 AM
Dxs's Avatar
Dxs
arent DA9 tie rods same as EF8?
i will get a friend to post in a sec..
Old Apr 23, 2008 | 01:14 AM
Dxs's Avatar
Dxs
well my friend just replaced his jdm ef8 sir outer tie rods..
said part numbers are
eft: 52560-SH3-N11 and Right: 52540-SH3-N11
cost him like 250AUD.. so 200USD
needed to come from japan too
we dont have a conclusion if any others match..
EE8 (euro b16 crx) i believe has a manual rack..
and DA9 (b18a teg) has the closest rack to the EF8, but dont know if the tie rods are the same
so yeah, good luck.. dont bother with honda australia either, most hate imports
Old Apr 23, 2008 | 03:33 PM
EFstyle's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i have ex knuckles for sale.</TD></TR></TABLE>
how much you want for em? I can get complete SiR knuckles for $100 so if its much more then that im just gona cut my inners and get those... (if thats all you have to do... )
Old Apr 23, 2008 | 04:01 PM
Tyson's Avatar
https://honda-tech.com/zerothread?id=2228975
Old Apr 23, 2008 | 04:04 PM
EFstyle's Avatar
Default Re: (Tyson)
well thanks for runnin it by me and its deffinitly a good deal but i think im better off with the SiR hubs...
Old Apr 23, 2008 | 04:32 PM
EFSiR's Avatar
I cut it my first time doing it but on my second time, I didn't and it's all good if you can put up with the fact that going straight will not have your steering wheel exactly straight but off by about 1 degree! No bigge, trust me.
Just remember to upgrade your MC to 1/16 bigger unit with the upgrade of integra calipers, which I'm assuming you'll be using.
HTH
Old Apr 23, 2008 | 05:14 PM
EFstyle's Avatar
Default Re: (EFSiR)
so you ended up screwing your outers all the way onto your inners and it lined up fine besides for the wheel being a lil off?
Old Apr 23, 2008 | 05:18 PM
EFSiR's Avatar
yes! just the steering wheel is 1 degree off. To fix that, you have to cut one end of the outer tie rod end and screw that into the inner tie rod all the way in. The other side is fine.
Old Apr 23, 2008 | 05:52 PM
EFstyle's Avatar
Default Re: (EFSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">yes! just the steering wheel is 1 degree off. To fix that, you have to cut one end of the outer tie rod end and screw that into the inner tie rod all the way in. The other side is fine. </TD></TR></TABLE>
you meen the end of one of the inner tie rod ends?
Old Apr 24, 2008 | 05:11 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Honestly... it seems like alot of work for something that can be grabbed off of a DA or ex sedan and work correctly.
Old Apr 24, 2008 | 07:10 AM
shenrie's Avatar
We put EF9 spindals on our 89 CRX without any mods and was able to get it aligned first try. The tierods were maxed out threaded in, but havent run into any issues yet.
Old Apr 24, 2008 | 01:24 PM
EFSiR's Avatar
Default Re: (ComeOnKip)
yes, the end of one inner tie rod end. Just a little part of it, I'd say if you cut the non threaded part, about 0.5"
gnxpro24
14
Jan 27, 2011 12:52 PM
tpod
22
Aug 8, 2006 08:37 PM
virginia_dude
Oct 4, 2005 02:06 PM
projecthybrid04
Jan 26, 2003 07:48 AM
Francois
11
Jan 7, 2003 05:34 AM
