wtb GSR HEAD
The second question belongs in tech, but you need a new headgasket, head bolts (or studs) and the block and head. This setup will not do much for you, unless you swap P30, itr, or ctr pistons into the block (ctr may be a bit much) and use itr or ctr internals in the head. Good luck in your search. Bump!
Down Shift Motoring
Nov 16, 2005 06:03 PM
crxste
Aug 19, 2003 08:16 PM
