(4th gen) JDM Healights....Headaches.
Old Apr 19, 2008 | 09:28 PM
JDMgareth's Avatar
Default (4th gen) JDM Healights....Headaches.
Think I posted this awhile back without luck, but here goes another shot:
Does anyone know a place to buy the plastic clip/plug part for the 4th gen JDM headlights? I need this piece to properly wire them up the way they are supposed to be.
I have already bought the PW:JDM kit and it is not what I need.
Thanks
*****EDIT*****
I'll post this in the "where can i find this" thread, sorry.
Old Apr 20, 2008 | 05:33 AM
oranginal's Avatar
Default Re: (4th gen) JDM Healights....Headaches. (JDMgareth)
if you want to hook up the dual filament bulb all you need is the 3 prong clip that goes into the bulb and a 5 pin relay. you then connect the 5 pin relay to the low beam positive, the high beam positive and negative, and the two outputs on the 3 prong connector that aren't the ground(there is a certain order of course this is just a summary). Then connect the ground of the low beam to the ground wire of the three prong plug.
Also when getting the relay see if you can gar a pigtail harness with it, it makes it much easier.
tdo
Sep 23, 2009 11:50 AM
IAluder95
Jul 29, 2005 06:19 PM
ViZ
Dec 6, 2002 07:45 PM
