FS: B18C, ARP, Eagle Rods, JE pistons, EM Racing, Type R grill...etc..etc.
List of things forsale:
Engine parts:
-1995 JDM GSR b18c complete engine/tranny: $1700
-1995 GSR intake manifold: $10
-1995 GSR shifter: $20
-96-99 integra LS engine harness uncut: $60
-b18b1 LS crankshaft (might need to be micropolish): $20
-b18b1 LS bare block (has some scoring, great for rebuild or bore): $10
-94-01 integra GSR inner (cut a piece on the bottom a little), outer timing belt cover: $20 both or $10 each
-99-00 civic si catalytic converter (Gutted straight thru): $40
-99-00 civic si oem exhaust manifold (2 piece): $40
-FastTurbo Vacuum manifold (no hoses): $15
-IACV from 96 acura integra LS: $10
-P06 5speed obd1 ecu (cover is bent but still works): $20
-P2E Auto obd2a ecu: $20
Exterior/Suspension/Wheels:
-Horn button don't know what brand but it looks JDM Yo!!!!: $15
-94-97 accord radiator support brand new: $30
-96-00 civic 2/3door sideskirts: $50
-96-00 civic 4door rear door handles (trim black): $15
-99 si prop valve: $10
-96-00 civic racing seat brackets by Wedge Engineering: $40
-92-95 civic eg momo SIR oem steering wheel non srs: $80
-99-00 civic Si blue hood: $70
-EM Racing triangular trunk bar (fits 92-00 civic/94-01 integra): $220
Prices are firm and I will delete whatever that has been sold. All parts are located in sacramento, if interested post here or pm me and i'll get back to u asap. Check back...page updated everytime parts are sold or new parts are added.
Modified by siblue_gzer at 12:15 PM 5/3/2008
Modified by siblue_gzer at 12:32 AM 5/8/2008
Modified by siblue_gzer at 4:00 PM 5/8/2008
Modified by siblue_gzer at 7:45 PM 5/10/2008
Engine parts:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A »</TD></TR><TR><TD CLASS="quote">2 vx rims only? how much?</TD></TR></TABLE>
i don't quite understand ur question but..
it's 2 hx rims and 2 vx rims. $240. the two tires on the hx are bfg drag radials which are over 200 bucks already. only ran a few times at the drag strip and took them off never used again.
if you're talking about parting the rims then i'll part the vx rims for $60. tires on them are still good..probably over 80% tread on both. hx rims will be $180
Mine are for GSR and LSVTEC which use the same ones. LS is different and will not work. yes they are used, but are in great condition. i only used them for about 500-600 miles.
