DIY LS/VTEC KIT
i know the golden eagle kit would be the best/proven method but has anyone here made their own kit? does the oil line need to be steel braided or can a piece of standard hydraulic hose be used on the fittings and clamped down. the fittings, hose, dowl pins and head gasket seem to be a bit cheaper if you fabbed up your own. im sure i could put a kit together for almost half the price. what do you guys think. please no flamming. just opinions as to why this is or isnt o good idea and explain yourself. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjbmx »</TD></TR><TR><TD CLASS="quote">when dealing with thiings like this its always better to spend the extra money and do it right</TD></TR></TABLE>
says who?
says who?
ya says who? people who don't know what they are doing, yes this is an easier way.
Here is a link to my ls/vtec build thready. I just bought Gates Industrial 300psi Hose with their Gator fittings good up to 300psi and a T-Fitting and some high pressure/temp teflon tape.
https://honda-tech.com/zerothread?id=2304434
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjbmx »</TD></TR><TR><TD CLASS="quote">im just sayin id rather spend $50 more and get some legit parts the macgyver my way though it, but then again thats just me</TD></TR></TABLE>
mcguyver is the **** though. i bet he'll build the most reliable lsvtec. ever.
I didnt buy a kit for my LS/VTEC. If you talk to Stealthmode62, he can set you up with all the oil lines you need for the conversion and at a VERY reasonable price too. He helped me out and i spent a ton less than the GE LS/VTEC kit.
yea i work in a semiconductor and the pipefitters told me they could build me a kit out of this.
http://www.swagelok.com/search...ype-1
these fitting are industrial grade fittings and hold chemicals like acid and alkaline. best part is they have bins of all kinds of fittings. its all free. if i give them measurements, they said they can fab me up a rigid line out of ss tubing.
QUESTION.....do you guys know what the inside diameter of 6AN is equal to in inches? is it like 5/16's or 3/8ths?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">
mcguyver is the **** though. i bet he'll build the most reliable lsvtec. ever.</TD></TR></TABLE>
i second that.
macguyver ftw!
i second that.
macguyver ftw!
Kidnkorner
28
Jan 12, 2004 03:39 PM
