what size heim joints do i need (traction bar)
Old Apr 19, 2008 | 04:55 PM
RACEPAK's Avatar
Default what size heim joints do i need (traction bar)
sup,
which size of heim joints/rod ends do you guys used on your traction bars?
thanks
Old Apr 19, 2008 | 07:38 PM
weiRtech's Avatar
OG Fabricator
i used 20mm ones for the first couple i did for myself, but found they were a bit overkill. 1/2" should be fine. that is what my traction bar kits are designed for, but you could use just about anything.
Old Apr 20, 2008 | 06:57 PM
1 2 NV's Avatar
Default Re: what size heim joints do i need (RACEPAK)
i used 1/2" also.
Old Apr 21, 2008 | 06:35 AM
dfoxengr's Avatar
Default Re: (weiRtech)
1/4 would most likely be strong enough to take all the forces, but it would look wimpy
Old Apr 21, 2008 | 09:59 AM
weiRtech's Avatar
OG Fabricator
1/4" is too small imo. especially on a model that already has tie rods coming off the stock front cross member like 88-91 civic/crx/integras.
Old Apr 21, 2008 | 10:07 AM
dfoxengr's Avatar
in tension/compression theyd be strong enough, but theyd look cheesy
00blksicivic
Suspension & Brakes
Mar 8, 2012 07:15 PM
accordfreak
Welding / Fabrication
Mar 12, 2007 10:20 AM
Liquidgsr
Suspension & Brakes
Jun 28, 2005 04:17 PM
