B16 SWAP IN EG ??????? HELP ASAPP
Old Apr 19, 2008 | 04:02 PM
EG*5*CIVIC's Avatar
Default B16 SWAP IN EG ??????? HELP ASAPP
I GOT A 00 SI B16 SWAPPIN INTO MY 95 CIVIC WHAT EXACTLY DO I NEED TO DROP IT RIGHT IN
I GOT THE
-P28 ECU
-OB2 JUMPER TO OBD1
-I GOT B16 MOTOR MOUNTS INTO A EG
WHT ELSE WOULD I NEED LIK ANY BRACKETS OR DO I HAV TO DO ANY MODIFICATIONS???
ALSOO CAN I USE THE SOHC THROTTLE CABLE FOR THE B16?????
Old Apr 19, 2008 | 04:13 PM
captivabluehatch's Avatar
Default Re: B16 SWAP IN EG ??????? HELP ASAPP (EG*5*CIVIC)
b-series shift linkage, any b-series throttle cable and bracket too.
Old Apr 19, 2008 | 04:17 PM
EG*5*CIVIC's Avatar
WHT SIDE DO I NEED BRACKETS FORR
Old Apr 19, 2008 | 04:21 PM
Default Re: (EG*5*CIVIC)
the throttle cable bracket that bolts to the intake manifold. if you can get one that one hole lines up in just use one bolt and tighten the hell out of it until you can get the proper one for it.
Old Apr 19, 2008 | 04:31 PM
EG*5*CIVIC's Avatar
THROTTLE CABLE BRACKETT???
I THOUGH I NEEDED THE DRIVERSIDE BRACKET AND BACK BRACKET AND A TRANNY BRACKET
Old Apr 19, 2008 | 04:57 PM
as far as mounts go you can use a stock civic rear and tranny. i have an ls/vtec so i have a teg driver side mount.
Old Apr 19, 2008 | 05:09 PM
I AM WEASEL's Avatar
What model 95 civic do you have, because you may have to do some wiring for vtec if you don't already have it. Also, that obd2 to obd1 jumper you have will not do you any good - it is for an obd2a/b (depending on what one you have) vehicle (1996-2001) to run an obd1 ecu (from a 92-95 vehicle)
Old Apr 19, 2008 | 05:26 PM
Default Re: (-DC4-)
thats what i was thinking. there is no obd2 p28 is there?
Old Apr 19, 2008 | 05:55 PM
EG*5*CIVIC's Avatar
I GOT A 95 CIVIC
I WAS THIKIN TO GET THE VTEC OBD2 HARNESS AND PUT A JUMPER ON IT TO OBD1 FOR THE OBD1 P28
Old Apr 19, 2008 | 06:08 PM
AGP-EG's Avatar
94-2001 Integra Rear mount T-bracket, it holds the tranny/motor mount together
94-2001 integra shift linkage, bolts right up
stock throttle cable, leave it alone and adjust it, thats it
left hand side motor mount BRACKET, 94-2001 integra, OR stock civic bracket
use your stock 95 civic engine harness on the motor, everything plugs up the same and it will be less of a hassle to work with your obd1 p28 ecu, just run a couple wires for vtec solenoid and vtec oil pressure.
everything else is pretty much the same, it's nothing all that complited at all really..why buy a obd2 engine harness and a jumper when you don't need it, lol it's a waste of time anyways and money.
Old Apr 19, 2008 | 06:24 PM
love of the sol's Avatar
First of all you need to search. Secondly for christ's sake please press the caps lock key, my ears are ringing.
Old Apr 19, 2008 | 06:43 PM
AGP-EG's Avatar
You mean it bothers your eyes, lol.
Old Apr 19, 2008 | 08:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG*5*CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">I GOT A 95 CIVIC
I WAS THIKIN TO GET THE VTEC OBD2 HARNESS AND PUT A JUMPER ON IT TO OBD1 FOR THE OBD1 P28</TD></TR></TABLE>
Even if you are using the engine harness from an integra or an ex you still will not need the ecu jumper. Again, the ecu jumper is so an obd2 vehicle (96-01 integra and 96-00 civic) can run an obd1 ecu. The only way you would need an obd2a/b-obd1 ecu jumper would be if you are using an obd2 cabin/interior harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captivabluehatch &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinking. there is no obd2 p28 is there?</TD></TR></TABLE>
There actually is an obd2 p28, but tuning it wont be liike tuning an obd1 p28 as there is no major tuning software that supports obd2 ecus (with the exception of k-pro, but thats another ballgame)
Old Dec 12, 2014 | 05:00 PM
White egg's Avatar
Just mounts ecu shift linkage b series cv axles b throttle cable harness and that's it
Old Dec 12, 2014 | 05:05 PM
Former User's Avatar
Seriously? This thread is 6 years old.
chrisff521
Mar 31, 2009 02:42 AM
b16nonoy
Feb 2, 2007 09:18 PM
sexyblack93lude
Oct 24, 2005 07:04 PM
