parts interchange question
I am planning on doing a auto to manual swap on my del sol, it is a 93 del sol. A buddy of mine is parting out a 92 EG Hatch. I know both cars are EGs but the OEM parts numbers on for example the shift linkages are different between the 2 cars.I was just wondering if someone can verify for me that all these parts are interchangeable between the 2 cars:
pedals? (all 3 of them)
shift linkage (including shifter)
front lower tranny mount (from tranny to frame by pass side wheel)
rear tranny mount (mount that bolts up to firewall where T brackets bolts to)
Clutch lines (from cylinder to cylinder)
reservoir (including rubber hoses)
slave and master cylinder
starter (which i know should fit cus both motors are D15s)
Thanks alot guys,
carlos
Thanks alot guys,
carlos
so the pedals,
starter
just not the shifter or shift linkage
are all the same?
Modified by acidburn2k2 at 8:04 PM 4/19/2008
starter
are all the same?
nnac7270
Jun 13, 2016 10:09 AM
civic, del, honda, hondas, interchange, interchangeable, interchanged, interchanging, motor, part, parts, prelude, rsx, sol, starter, tsx
