Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL
Old Apr 19, 2008 | 02:38 PM
Kr0n1k's Avatar
Default Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL
Well here is the problem i've been trying to fix for a month:
I'll start by saying the car is a 96 Integra GSR with conversion harness to OBD1 JDM P72 GSR ECU with a JDM B16A OBD1 motor GSR distributor.
I just swapped all these parts into this shell so the car really has yet to run correctly.
So it idles very rough when I hit the gas it will misfire at about 2K and when it hits 3K will cut off fuel if full throttle. If I try I can sometimes get it to 4K at which point the tach will drop to 0 RPM and the engine acts like it hit a rev limiter.
The car basically runs like severe ****. I don't know if i want to take it on a main road because i'm afraid of what will happen if I do.
The strange thing is I onced changed the charcol canister and it ran almost normal! But this only lasted for 2 hours and it would actually stall at stop signs. I parked it for 4 hours came back to start it - no start. Found the coil burnt out (spotting on insulation). Changed the coil started up with orignal problem. Fried coil again. Replaced with MSD external coil this time.
Heres what I have tried with known good parts :
Replaced FPR, Fuel pump , Ignition control module (3 times) , coil (4 times), MSD coil, ECU (P75, P72 OBD1), checked grounds (tranmission, engine, thermostat), ohm check on each injector okay, charcoal canister, compression tests all cylinders even, dont have fuel pressure guage or vacuum guages. There has never been a check engine light on.
My next guess is to change the engine harness. Maybe its messed up because someone wired VTEC???
I dont think its the O2 or PCV or FITV or IACV or TPS just because it ran normal that one day. I'm starting to think its just an electrical thing but I'm about out of ideas and am just praying for a CEL.
Anyone ?? Please help I've done 10 engine swaps and put shells together in less time then I've spent on this and its driving me insane!!!!!!
Old Apr 19, 2008 | 02:50 PM
Rickdrizzle's Avatar
spark plug?
Old Apr 19, 2008 | 04:46 PM
Kr0n1k's Avatar
Default Re: (Rickdrizzle)
Well I should also mentioned I've replaced the entire ignition system minus the distributor housing. Plugs (NGK), wires (tried used and new ones), cap, rotor, igniter, coil.
No vacuum leaks, just replaced all vacuum lines.
Update:
Just drove it for twenty minutes around the neighboor hood, can't get it over 20MPH car jerks hardcore @ 2k RPM any gear and tach bottoms out, complete loss of power ... no stalling at all though. Once i let go of throttle I can get back to 2K if I use less than 25% throttle or so. Tried to uplug TPS same effect, unplugged MAP sensor, engine stalled. Restarted with no problem.
Worth mentioning that after warming up, the car now idles perfectly... WTF?!?!
Someone please give me some ideas as I'm going insane trying to figure this out.
Old Apr 19, 2008 | 04:59 PM
Kr0n1k's Avatar
Default Re: (Kr0n1k)
I wonder if its the CYP CKP TDC sensors? I wish this thing would throw a check engine light this is ridiculous. Fuel filter maybe? I doubt it but I'll change it anyway.
Old Apr 19, 2008 | 06:15 PM
Kr0n1k's Avatar
Someone with the same problem said they changed their TPS sensor and it fixed it. I'll test it then replace if nec...
Old Apr 20, 2008 | 12:04 AM
KillerMTRsports's Avatar
injector plug???
Old Apr 20, 2008 | 07:21 AM
b20integrapower's Avatar
Default Re: (KillerMTRsports)
you really didnt change the dizzy out yet?
When something like what you are describing happens, the first thing you should check is the distributor. Did you even change the cap n rotor? I bet its the cap and rotor or the whole distributor went to ****.
Old Apr 22, 2008 | 10:19 AM
Kr0n1k's Avatar
Default Re: (b20integrapower)
Well yeah if you read my post I said I changed the distributor parts minus the housing, I would throw a dizzy at it but I can't afford 200 guess. Not to mention noone I know has one I can borrow. Ill post a update after the tps and fuel filter and o2 sensor change tonight. Any more ideas or experiences would be appericated.
Old Apr 22, 2008 | 06:59 PM
Kr0n1k's Avatar
Well, I replaced the fuel filter and TPS sensor no difference. Spark plugs are carbon fouled. Only thing left is the actual distributor but why won't it throw a crank sensor code or something... anyone in Denver got a VTEC dizzy that I can borrow??
Old Apr 22, 2008 | 08:08 PM
B18Cyko5's Avatar
my friend is going to let me borrow his gsr dizzy. i'll let you kno how that works out for me. same here with the time consuming, money pit. lol it's driving me insane.
Old Apr 22, 2008 | 08:18 PM
Presto800's Avatar
Had the same problem on my last teg, and it was my dizzy.
On my current teg it was my TPS. Make sure your TPS is adjusted. Tap into the ground wire (i think its black) with something that you can hook a volt meter up to and adjust the TPS VERY carefully so that the voltage reads between .45 and .5 volts.
I really doubt that will fix your problem though, I'm almost positive you need a new distributor.
Old Apr 22, 2008 | 08:55 PM
Default Re: (Presto800)
I will reiterate myself and say it is your distributor. Just because you replaced the replaceable parts doesn't mean the distributor can't be done for.
Old Apr 23, 2008 | 04:44 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL (Kr0n1k)
What does the exhaust look like? Is it running rich, etc.?
Old Apr 23, 2008 | 05:10 AM
b18_integra's Avatar
yeah my integ is doing the samething i replaced everything including the cap and rotor but come to find out it was the whole dizzy
Old Apr 23, 2008 | 08:16 AM
Kr0n1k's Avatar
Yes it has to be the dizzy considering it burned 3 coils. I had suspected it the whole time but I just don't have a test one. Guess ill risk a 200 guess from disturbitor king....
Old Apr 23, 2008 | 09:03 AM
gl and please let us know.
Old Apr 23, 2008 | 02:02 PM
Scud's Avatar
yea let us know what happens please!
Old Apr 24, 2008 | 05:34 PM
Kr0n1k's Avatar
Default Re: (Dogginator)
Yea its running rich. Plugs are carbon fouled, its obviously getting gas! About to buy a distributor tomorrow...hey B18Cyko5 did you borrow your friends distributor? What happened?
Old Apr 24, 2008 | 06:24 PM
Kr0n1k's Avatar
Bump
Anyone else fixed this problem with a distributor replacement?
Old Apr 26, 2008 | 04:37 PM
Presto800's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kr0n1k &raquo;</TD></TR><TR><TD CLASS="quote">Bump
Anyone else fixed this problem with a distributor replacement?</TD></TR></TABLE>
Read the thread. Like 4-5 people in here have fixed this problem by replacing the distributor.
Old Apr 26, 2008 | 10:36 PM
THE STIG4's Avatar
New User
Default Re: Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL (Presto800)
try the dizzy. for what you said before, its seems like some wire with power its fring the coils and modules. It hjappened to me once when some one installed an OBD I dizzy into and OBD II harnes without using the right dizzy hanrnes. Good luck man, hope this helps you fiz your problem.
Old Apr 28, 2008 | 07:07 AM
Kr0n1k's Avatar
Default Re: Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL (THE STIG4)
Problem resolved!
Obviously the ecu was losing the crank sensor signal and a new distributor fixed it.
Now redlining with no misses.
Engine light would have been helpful lol.
Old Apr 28, 2008 | 08:50 AM
Wow. Isn't that some ****.
I'd listen next time
Old Apr 28, 2008 | 12:05 PM
jjitr's Avatar
try changing the igniter coil
Old Apr 28, 2008 | 02:04 PM
Scud's Avatar
Default Re: Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL (jjitr)
so you got it fixed? good to hear that! im about to work on mine this weekend.. i hope its not the distributor.. how much did one of those run you? and is there anyway to check if the distributor is bad or do i just have to get another one and try it?
Freemananana
Sep 21, 2015 09:01 AM
dynimitejack
Sep 24, 2008 12:50 PM
