spark plugs
Old Apr 19, 2008 | 02:28 PM
spintboy's Avatar
Default spark plugs
Can someone give me the corect measurments to gap my spark plug.
I got a 98 integra type r motor btw. Thanks.
Old Apr 19, 2008 | 03:04 PM
00-501itrspec's Avatar
Default Re: spark plugs (spintboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spintboy &raquo;</TD></TR><TR><TD CLASS="quote">Can someone give me the corect measurments to gap my spark plug.
I got a 98 integra type r motor btw. Thanks.</TD></TR></TABLE>
It didn't occur to you to look somewhere for your answer?
im sure if you googled " what is the correct gap for my spark plugs in my 98 ITR " ,
im SURE you can find the answer there .
SEARCH is a good friend , all you gotta do is use it .
I know the answer to your question , im not telling you because of how easy it is to find that out , not cuz im a dick
( or because this thread is better off being in the all-motor , or the Performance areas of Honda-Tech , not the Type-R area , FYI.)
Modified by 00-501itrspec at 7:15 PM 4/19/2008
Old Apr 19, 2008 | 04:11 PM
spintboy's Avatar
Default Re: spark plugs (00-501itrspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by 00-501itrspec at 7:15 PM 4/19/2008</TD></TR></TABLE>
Are you happy now? lol
Old Apr 19, 2008 | 06:35 PM
vinuneuro's Avatar
NGK's are the oem plug maker, and they come pre-gapped.
Old Apr 19, 2008 | 09:56 PM
neo_'s Avatar
Default Re: spark plugs (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">NGK's are the oem plug maker, and they come pre-gapped.</TD></TR></TABLE>
Not always the case.
Old Apr 20, 2008 | 12:01 PM
vinuneuro's Avatar
Default Re: spark plugs (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">
Not always the case. </TD></TR></TABLE>
I used to check the gap on ngk's, never have had a plug that's deviated from the oem spec.
Old Apr 20, 2008 | 06:15 PM
Rdriver's Avatar
The last to numbers are the gap in mm on NGK plugs. I use pfr-7g-11 which is 7 heat range 1.1 mm gap or .044 in.
pliskin8
Jul 31, 2008 11:44 AM
buffgsr
Mar 25, 2008 04:56 PM
kevaccord
May 10, 2007 01:29 PM
Calean007
May 9, 2005 07:04 PM
90TT
Nov 25, 2004 08:45 AM
