HELP!!!!!!! B20A swap in a 89 rex
Old Apr 19, 2008 | 11:20 AM
89CRXProject's Avatar
Default HELP!!!!!!! B20A swap in a 89 rex
ok, im about to put the b20a motor from a 91 Prelude Si into my 89 crx
the motor has about 80k miles on it, and its a 5 speed manual
what do i need, im just buying the motor and tranny
i know i need axles ecu and motor mounts, but what kind, and am i going to have to do any special modifications to make the tranny fit?
if anyone has done this swap in there crx or civic please help me
also, will i have enough room for a turbo kit in my engine bay? i want to reliably boost it, maybe about 4-6 PSi or so
please help, im a 18 year old kid that is doing a motor swap for my first time, if theres any things i should know about that are key factors let me know
thanks
Old Apr 19, 2008 | 11:35 AM
gibsanez's Avatar
Default Re: HELP!!!!!!! B20A swap in a 89 rex (89CRXProject)
This is not the same engine as the B20B/Z. You would have to make your own mounts, and axles would be questionable as well. It's really not worth it. There are far more cost effective swaps for the EF.
Old Apr 19, 2008 | 11:43 AM
well i have the motor sitting in my garage and it runs, so all i would need is components
so i got the tranny and motor, so thats most of the cost right?
Old Apr 19, 2008 | 12:31 PM
Deetz's Avatar
Crazy Honda Guy
My suggestion, get rid of that engine. It's not a regular b series like other motors. It will not bolt in, nobody makes a mount kit for it, you would have axle issues, plus that motor really isn't that good.
A B18A would probably be more up your alley.
Old Apr 19, 2008 | 12:34 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (89CRXProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89CRXProject &raquo;</TD></TR><TR><TD CLASS="quote">so i got the tranny and motor, so thats most of the cost right?</TD></TR></TABLE>
No, you have forgotten:
- new clutch
- timing belt
- throttle cable
- (important) the prelude tranny is a hydro unit, will not work without conversion
- wiring, not to mention clearance issues
Old Apr 19, 2008 | 12:47 PM
deetz.
it has a new atc clutch and belts
but needs axles ecu (was planning to convert to obd 1)
and hydro clutchs are better then cable, arent they? so it would be worth it to convert to hydro right?
and wont the hasport efb1 mounts fit on the b20a? they fit for b20b, and b18a,b,c im not sure though
Old Apr 19, 2008 | 12:51 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89CRXProject &raquo;</TD></TR><TR><TD CLASS="quote">deetz.
and wont the hasport efb1 mounts fit on the b20a? they fit for b20b, and b18a,b,c im not sure though</TD></TR></TABLE>
No, the B20A is a totally different motor from any other Honda engine, it is a "one off" black sheep and shares no other parts with other b series engines. The mount kits you see will not work at all with the engine/tranny
Old Apr 19, 2008 | 12:56 PM
hmm
well i bought the motor last month for 400$
what do you suggest i should do?
Old Apr 19, 2008 | 01:58 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89CRXProject &raquo;</TD></TR><TR><TD CLASS="quote">hmm
what do you suggest i should do?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote"> It's really not worth it. There are far more cost effective swaps for the EF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">My suggestion, get rid of that engine. It's not a regular b series like other motors. It will not bolt in, nobody makes a mount kit for it, you would have axle issues, plus that motor really isn't that good.
Just sell it to someone else.
Old Apr 19, 2008 | 04:12 PM
I heart My EF Sedan's Avatar
Default Re: (gibsanez)
yea just sell it to someone with a prelude that needs a new motor... the b20a should've been designated a different letter because it is way different than any other b-series...
Old Apr 20, 2008 | 05:12 PM
thanks guys for the usefull information
, i sold the b20 to a guy who needed it for his lude, he blew up his motor and was looking for it, so he gave me 615 bucks
and i picked up a gsr for 1000 bucks that has 50k miles on it, came with intake mani, stock headers , and ecu and dizzy, but it needs tranny and axles, and i need motor mounts
wheres the best place to find a new tranny and axles for this motor? i decided hasport motor mounts, but if anyone knows where i can get cheaper ones that are just as good let me know. but i doubt there is, ya get what u pay for :-P anyways
thanks for the usefull information,
Old Apr 20, 2008 | 05:48 PM
gibsanez's Avatar
Innovative makes nice mounts, I'm very happy with mine
Old Apr 21, 2008 | 03:06 PM
awesome, what about axles and tranny?
Old Apr 21, 2008 | 05:45 PM
gibsanez's Avatar
Transmission, you can use any B series trans you want really, but if it's a hydro trans, you'll have to buy a conversion kit to use it. Match axles to the transmission (90-93 teg/94+teg, etc)
If I were you, I'd look for a 92-93 integra GSR trans, or a cable B16 trans, and I'd avoid the LS transmission.
Old Apr 21, 2008 | 06:14 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Transmission, you can use any B series trans you want really, but if it's a hydro trans, you'll have to buy a conversion kit to use it. Match axles to the transmission (90-93 teg/94+teg, etc)
If I were you, I'd look for a 92-93 integra GSR trans, or a cable B16 trans, and I'd avoid the LS transmission.</TD></TR></TABLE>
Thats only kind of right....you match the axles to the intermediate shaft. You can have a 1990 b series tranny with 94+ shaft and axels.
As far as an LS tranny for B20, i have one in y hatch, car goes like hell, no complaints except traction, which would only be worse with a vtec gearbox.
Old Apr 21, 2008 | 06:22 PM
gibsanez's Avatar
Default Re: (Deetz)
Thanks for the correction, I wasn't paying that much attention when I wrote it.
Old Apr 22, 2008 | 05:03 PM
ok thanks a ton guys, this cleared up alot for me
im gonna eventualy turbo it to, is there anything i should worry about on the axles for turbo? im gonna be pushing light boost, probably 6-7 pounds, what would be the best turbo to put on this application
b15
Dec 30, 2009 02:51 AM
crxproject87
Classic Hondas
Mar 21, 2008 07:43 PM
89accordsei
Nov 19, 2007 02:51 AM
dson78
Oct 16, 2002 06:20 PM
