Crx Battery
Relocation, apparently I'm still new and can't post anywhere else.
Anyway I've searced and searched some more. All I want is to know if I have it down before I go blowing fuses and causing more problems!
I was planning on relocating my battery to my trunk, its an oem replacement will this leak gases? Can I just extendz my positive wire to the trunk? Can I ground the tranny to frame rail and all will be fine? Or would it be better to relocate in the engine bay by the tranny and use everything as it is?
haha I'm really sorry for all this but any imput would be greatly appreciated.
If I have things right a simple 'yes' is great!
If your relocating to the back, you might want to consider getting a sealed battery. The Odyssey PC680 batteries are pretty popular. Small, lightweight, and sealed. Also if you do relocate and are ever going to track your car, you'll need an outside mounted kill switch.
And a little searching goes a long way. Some write-ups that should clear the majority of your questions:
http://crx.honda-perf.org/arti....html
http://www.fourthgenhatch.net/battery.html
http://www.homemadeturbo.com/t....html
And search the archives, you should get plenty of results. Good luck.
