any one ever had trouble removing the axle from the halfshaft?
Old Apr 18, 2008 | 09:47 PM
LS94tegra's Avatar
Default any one ever had trouble removing the axle from the halfshaft?
i ended just removing the halfshaft and axle in one piece whats the best way to remove the axle from the half shaft if its stuck?
Old Apr 18, 2008 | 11:31 PM
gtec8285's Avatar
Default Re: any one ever had trouble removing the axle from the halfshaft? (LS94tegra)
yea i had a problem with that before but the reason was i snap my axle the part that goes in the axle is where it snap so i took it out and pound it down to the ground till it came out piece by piece.
Old Apr 19, 2008 | 07:40 AM
88civic's Avatar
yep very common! get an air hammer with the pickle fork attachment or the blunt attachment and try that!
good luck!!
oh and when you get your new axle grease the ends so that it is less likely to happen again!!
Old Apr 19, 2008 | 11:59 AM
ivan93egreppin210's Avatar
Default Re: any one ever had trouble removing the axle from the halfshaft? (88civic)
this was the most time consuming part of pulling my motor. i would have been done in like 2 hours but i was stuck on the axle for like an hour. in the end i just beat the **** out of it with a hammer. watch out for knuckle busters. dont try to just pull the axle out. i seperated mine and had to open the boot to put it back together. good luck.
integrainside
Transmission & Drivetrain
Oct 3, 2013 05:21 PM
grjr
Aug 23, 2012 04:12 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
Endo-land
Sep 9, 2007 08:12 AM
Feb 19, 2004 08:54 PM
