Power door converted to manual? Can it be done?
Old Apr 18, 2008 | 08:09 PM
Nickboxer7's Avatar
Default Power door converted to manual? Can it be done?
I've got a 94 Civic hatch with manual everything and I am looking at a 2 or 3 door passenger door that had power windows and door locks. It's the same looking setup, so is it easy to swap my manual window rails over and all the locking mechanisms? I thought I had read all the holes are in each door, just some are filled with plugs on the power ones.
I need to know before I buy the power door how hard it is to swap everything into it and if it will work.
Old Apr 18, 2008 | 08:15 PM
bpr0422's Avatar
Default Re: Power door converted to manual? Can it be done? (Nickboxer7)
it shouldn't be too hard to swap everything over..
what about getting both doors, some harnesses and convert the car to power...
Old Apr 18, 2008 | 08:18 PM
Nickboxer7's Avatar
Default Re: Power door converted to manual? Can it be done? (bpr0422)
That might be possible. I believe the guy already sold the switches for it though. I have autoloc actuators installed in my car with keyless entry so I don't really need that, just power windows, which I am old school there and 90% of the time like the manual cranks
I might see what he has left. The door is only 20 bucks hopefully which is a great price :D
Old Apr 18, 2008 | 08:22 PM
bpr0422's Avatar
you can wire the oem actuators to your alarm..
see if you can get the power door inserts, and switches
Old Apr 18, 2008 | 08:32 PM
Nickboxer7's Avatar
What all wiring would I need? I think there is wiring from the drivers door that goes and plugs in under the dash near the steering wheel. I believe there is a relay in the fuse box that is needed too, but I had one somewhere. I'm just not sure everything I would need to get for that and if he still has the car wiring.
And someone else asked about the drivers door so if that is gone I'm just going to leave it manual, as long as that can work.
First.EG
Mar 10, 2012 04:20 PM
jeffsciv23
Dec 20, 2005 10:30 PM
Dropped90Integra
Feb 2, 2005 09:00 AM
Kev95lx
May 15, 2003 05:40 AM
