jdm itr 5lugz suspension (36mm) with axles...PLEASE HELP!!!
Old Apr 18, 2008 | 07:27 PM
o-eazy's Avatar
Default jdm itr 5lugz suspension (36mm) with axles...PLEASE HELP!!!
I tried using a 97 crv axles and it was still too long. i took my old integra axle and took the outer cv joint out and replace it with a 90 accord outer cv joint but the inner spindle was bigger than my old integra shaft. im confuse on what yr or car to use the outer cv joint from. should of been smarter and bought the 32mm one. ive spent alot just on axles so far and find out that doesnt even work.
Old Apr 18, 2008 | 07:45 PM
SuckMyDOHC's Avatar
Default Re: jdm itr 5lugz suspension (36mm) with axles...PLEASE HELP!!! (o-eazy)
You did the wrong thing both times. CRV axles are NOT a direct swap and you need 94-97 Accord or 92-96 outter CV Joints on your Integra axles.
Old Apr 20, 2008 | 02:52 PM
o-eazy's Avatar
Default Re: jdm itr 5lugz suspension (SuckMyDOHC)
so that means i could just buy a 94-97 accord driver side axle and it would just fit right in without having to just take the outer cv joint out?
Old May 15, 2008 | 02:28 AM
legomytego's Avatar
bump for this i am in the same hole ive spent a good amount on axles only to find out they dont work as far as going to swap the crv on the outter axle of my stock one i also noticed its alittle long
lowlowloweg6
Jan 7, 2016 04:12 AM
Mfoehrkolb
Nov 7, 2010 09:20 PM
DragSource
Feb 27, 2005 04:32 PM
type Gendy
Jan 19, 2003 06:18 PM
Prelussion
Nov 15, 2001 12:51 PM
