No Fuel!!
Old Apr 18, 2008 | 05:52 PM
mikester1222's Avatar
Default No Fuel!!
alright i got a 92 honda civic and i put a b18b and i have spark and comprestion but no fuel there is fuel going to the rail but nothing comeing out off the injectors can someone give me like all the posible things that could be wrong then say how to fix it? if you have any ideas i am up for it!
Old Apr 18, 2008 | 05:55 PM
cherroneballs's Avatar
do you have both plugs on the driver side shock tower hooked up??? one is for injectors. also check all grounds.
Old Apr 18, 2008 | 05:59 PM
Default Re: (cherroneballs)
yes and where do all the grounds need to be?? that may be my problem i may be missing a ground wire somewhere!!
Old Apr 18, 2008 | 06:05 PM
thermostat housing, tranny, front of valve cover, thats all I can think of right now.
Old Apr 18, 2008 | 06:06 PM
got them all grounded!!!!!
Old Apr 18, 2008 | 06:08 PM
still no luck???
Old Apr 18, 2008 | 06:11 PM
nothing!! not a single drop of fuel shooting into those cylinders!!
Old Apr 18, 2008 | 06:13 PM
blk_eg4's Avatar
Default Re: (mikester1222)
check ECu or maybe the injectors..
Old Apr 18, 2008 | 06:14 PM
your not using obd0 injectors? right? I guess check all connections, injectors, ecu shock towers. How do you know your not getting fuel through the injectors??? just curious.
Old Apr 18, 2008 | 06:18 PM
blk_eg4's Avatar
check ecu or injectors...
Old Apr 18, 2008 | 06:19 PM
Default Re: (blk_eg4)
its the injectors that came with the motor!! so they could have been changed! and i got a new ecu for it! the way i know there not shooting any gas is i have spark but its not even trying to fire and i pulled the spark plugs out and they where all dry!
Old Apr 18, 2008 | 06:21 PM
i also took the headers off and there is not even a smell of gas! when trying to start it
Old Apr 18, 2008 | 06:27 PM
Former User's Avatar
Blown fuses? Faulty main relay?
Old Apr 18, 2008 | 06:30 PM
Default Re: (RonJ@HT)
where is the main relay located at??
Old Apr 18, 2008 | 06:36 PM
Old Apr 18, 2008 | 06:54 PM
i will check this cuz come to think of it i had the same problem with my crx and thats what the problem was never crossed my mind though!
Old Apr 18, 2008 | 06:56 PM
good thinkin' on the main relay. comin' problem, forgot all about that stupid thing.
Old Apr 18, 2008 | 07:32 PM
1990_integra_DA9's Avatar
the PCM supplies the ground to the injectors
rlembitz
Dec 24, 2010 09:04 AM
Lmgrcivic
Sep 25, 2010 04:25 PM
tbuck23
Apr 24, 2007 01:12 PM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
shreddinryguy
Jun 26, 2005 01:28 PM
