torque specs. tranny to block?
Old Apr 18, 2008 | 04:18 PM
slo_ej8's Avatar
Default torque specs. tranny to block?
i dont have a helms or anything at the moment. anyone know what the torque specs are for a b16 tranny to block? i think its 47ft lbs?
Old Apr 18, 2008 | 04:52 PM
slo_ej8's Avatar
Default Re: torque specs. tranny to block? (slo_ej8)
bump
Old Apr 18, 2008 | 05:23 PM
Hanmin's Avatar
Just tighten it down like how you would with a tire.
Old Apr 18, 2008 | 05:38 PM
Dasfinc's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">Just tighten it down like how you would with a tire.</TD></TR></TABLE>
Wheels have torque specs too... 100ft/lb typically, some 80-90 also
Honestly though, I did just that with my trans, I just tightened them till they were tight as I felt good Not saying this is a good thing, but it hasn't fallen off the car yet....
Old Jun 1, 2009 | 04:24 PM
jdoc325's Avatar
bump! i need to know this too... i know this thread is mad old but im doing my clutch
Old Jun 1, 2009 | 04:29 PM
1992Si's Avatar
That's what I have alway's done when I install trannys. BTW I'm 54 y/o I've done a few tranny's.
I alway's torque lug nut's to 80ftlbs some things are important others are not.
Old Jun 1, 2009 | 04:47 PM
boostB4beauty's Avatar
agreed.
I Re&Re at least 2 trannies a month at work..... i haven't torqued a bellhousing bolt yet.....
just tighten it........
Old Jun 1, 2009 | 05:35 PM
solsilum's Avatar
Manual calls for 47 ft. lbs for bell housing bolts and 33 ft. lbs for starter bolt. Hope this helps.
Old Jun 1, 2009 | 07:45 PM
TheJGB3's Avatar
ALL HONDAS ARE 80FT/LB on the lugnuts (alloy or steel wheels)
Old Jun 1, 2009 | 09:19 PM
98civdx's Avatar
Master Detailer
just get it on there good and tight, but if you want to torque them its not going to hurt anything.
Old Jun 1, 2009 | 09:36 PM
waaBAAH's Avatar
even the ridgeline? hmm..thought those might be the beefiest of them all.
SIXTY
Jan 13, 2007 04:32 PM
lx-sedan
Jun 24, 2006 05:31 AM
Stinkycheezmonky
Jun 9, 2005 03:13 PM
InfamousGSR
Apr 15, 2004 02:16 PM
Evs-One
Apr 16, 2003 05:47 PM
