fender removal
Can anyone point me towards a guide or some write up that tells how to remove the fenders? I didn't find directions inside the Accord FAQ so I made this thread. Any help will be greatly appreciated, thanks.
If I remember correctly, you'll have to remove the front bumper to get at one mounting bolt. Remove the splash guards and fender liner. Remove the rocker covers (or at least the first few retainers and pull the front down) to access a bolt covered by them. Open the doors to access two bolts near the top and bottom, then the three or four bolts across the top.
Ah, thanks. That worked out fine.
I have another question though. Has anyone else purchased the JDM spec fenders from passwordjdm? I'm wondering how I'm supposed to go about wiring them as well. So anyone with experience, your input will be appreciated.
i purchased them (then they were stolen) and i purchased them again....i wired my first sidemarkes to blink with the turn signals(splice into turn signal harness) . The second set i had them stay on constantly looked better IMO (you can actually cut off one of the corners bulbs if you have a 96/97 cuz neither of them blink) <----only if you have the black/chrome housing corners
