why wont my car start
Old Apr 18, 2008 | 02:33 PM
JCritt's Avatar
Default why wont my car start
i left it there for a month and a half.
i come back from vacation and it wont start. sounds like it wants to start , but the motor never does
help?
Modified by JCritt at 12:10 AM 4/19/2008
Old Apr 18, 2008 | 03:30 PM
MasterShake's Avatar
did it start when you left?
try the basics, check for spark gas and cel's
Old Apr 18, 2008 | 08:14 PM
1990_integra_DA9's Avatar
Default Re: why wont my car start (JCritt)
Agree with checkin the basics. Could be a fuel pump:no fuel, Spark, compression. But sitting for a while. Could be a fuel pump.check for voltage back at the pump. Turn the key on do you hear the pump run?
Old Apr 18, 2008 | 08:45 PM
EkFG's Avatar
Default Re: why wont my car start (1990_integra_DA9)
like they said, check for the basic... Hey maybe someone stole your gas, lol j/k
Old Apr 18, 2008 | 09:42 PM
rpoosua's Avatar
Remove the igniter and have Advance Auto or autozone tested.
Old Apr 18, 2008 | 10:37 PM
katoeh2o's Avatar
Default Re: why wont my car start (rpoosua)
battery? Or is that to obvious.
Old Apr 18, 2008 | 10:48 PM
obuhmyuh's Avatar
you left it for a month? im guessing you didnt disconnect the battery terminals.
i bet your battery is dead.
edit: i would actually bet money it is your battery.
Old Apr 18, 2008 | 11:57 PM
jdmej814's Avatar
Default Re: why wont my car start (obuhmyuh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh &raquo;</TD></TR><TR><TD CLASS="quote">you left it for a month? im guessing you didnt disconnect the battery terminals.
edit: i would actually bet money it is your battery.</TD></TR></TABLE>
x2...tahts the obvious reasons, happened to my moms 2wice already, call AAA.....
Old Apr 19, 2008 | 05:37 AM
eskimo10's Avatar
well OP said that it sounds like its wans to start, but never does. so would that be a battery? I mean in my experience if a battery dies then I get a clicking. Motor may try to crank but after about 5-10 seconds it dies and goes straight to clicking.
I agree to check the basics. Could be a bad stater as well. Just some more ideas to try.
Old Apr 19, 2008 | 10:01 AM
obuhmyuh's Avatar
Default Re: (eskimo10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">well OP said that it sounds like its wans to start, but never does. so would that be a battery? I mean in my experience if a battery dies then I get a clicking. Motor may try to crank but after about 5-10 seconds it dies and goes straight to clicking.
I agree to check the basics. Could be a bad stater as well. Just some more ideas to try.</TD></TR></TABLE>
depends on how drained said battery is. it just might not have enough to turn the motor over (turn the starter to get the motor going), thus it "sounding" like it wants to start but never actually starting.
It could be a starter, but not likely, a car not started after a long time generally would not kill a starter.
Old Apr 23, 2008 | 07:30 PM
Default Re: (obuhmyuh)
if it cranks over then its prolly not a starter. All the starter does is assist the engine in turning over. If it cranks its prolly not the starter. CHECK FUEL, SPARK, COMPRESSION.
Old Apr 23, 2008 | 08:15 PM
Civic_07's Avatar
check ur dizzy as well
Old Apr 23, 2008 | 08:19 PM
EkFG's Avatar
Default Re: (Civic_07)
have your battery charged. change your spark plugs and check you cap and rotor. bet that will get you going.
Old Apr 23, 2008 | 10:13 PM
obuhmyuh's Avatar
i love when people post their question and they get a billion hints an tips and they dont respond. f|_|ckin 1 post wonder.
Old Apr 24, 2008 | 10:03 AM
eskimo10's Avatar
hey man i ain't trying to be a jerk or nothing, but he does have almost 3000 posts. Could just be really busy. who knows.
Old Apr 24, 2008 | 10:21 AM
obuhmyuh's Avatar
that's fine but i guess he's problem isn't that serious if he doesn't care enough to check back, or if it was something stupid like a battery he could say something like hey thanks or problem solved. i could give 2 ***** about 3k posts, I have no idea where he got them, could be FS threads or gen discussion for all i know.
Old Apr 24, 2008 | 06:57 PM
mouab18c1's Avatar
ahaha help me out fellas.. my car was running but checked it with a timing gun and noticed that my tdc mark was nowhere to be found so i took off the valve cover took off my cam covers loosened the belt and redid everything...this would be my 50th time doing timing ahaha or some shyt like that..but after i got it back together car wouldnt start...cranks but nothing...checked and i do have fuel spark and compression...car has been dead for a week...help me out guys..i feel like crying without my car running
Old Apr 24, 2008 | 08:25 PM
JCritt's Avatar
Default Re: why wont my car start (mouab18c1)
found out it was the fuel. my fault if i didnt check in earlier, busy with school
alright thanks fellas... , case close [/nyluder]
Old Apr 24, 2008 | 08:59 PM
to the guy up two spots ^^^^^^
First...what year is your car?
Second....are your timing marks correct?
You may be getting fuel..but are the injectors firing the fuel?
Old Apr 24, 2008 | 09:22 PM
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 &raquo;</TD></TR><TR><TD CLASS="quote">to the guy up two spots ^^^^^^
97 built b18c1....timing marks are legit getting fuel but dont know how to check if the injectors are firing.....
Old Apr 25, 2008 | 03:07 PM
crooklyn_outlaw's Avatar
have one person sit inside the car and turn it to the on position while you listen to the injectors...
Old Apr 25, 2008 | 06:51 PM
Default Re: why wont my car start (crooklyn_outlaw)
that isnt the inectors making noise when you turn your key on...thats your fuel pump. You can check to see if the injectors are firing by pulling the injectors out with the fuel rail attached. Put a small cup or trey under them and have someone crank to see if they are firing.
Old Apr 25, 2008 | 10:15 PM
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 &raquo;</TD></TR><TR><TD CLASS="quote">that isnt the inectors making noise when you turn your key on...thats your fuel pump. You can check to see if the injectors are firing by pulling the injectors out with the fuel rail attached. Put a small cup or trey under them and have someone crank to see if they are firing.</TD></TR></TABLE>
thanks..ill try that
Old Apr 25, 2008 | 10:45 PM
HondaGuy951's Avatar
either battery, or possible that ur gas got diluted... but like everyone else said....check basics
Old Apr 25, 2008 | 10:59 PM
RDAYA0's Avatar
Default Re: why wont my car start (HondaGuy951)
Try boosting it
