Built D16 Forsale
Has All New Gaskest Engine Is Clean Running Wth No problems Build Is Not even A week Old Has Not even Seen 100 Miles Built To Sell Going Boost Next Month And Had To get Old engine Out To build Now Ready To Sell
Make Offer
<U>Bottom End (d16a6)</U>
New honda Oil Pump
New water Pump
New Timing belt
New NPR Rings
New Acl Bearings
Arp rod Bolts
Brand New P29 .5mm Over
z6 Rods
Micro Polished Crank
Arp Head Studs
GSR Thermostat
Stock Flywheel
Act 4 Puck Clutch Disc
Centerforce Pressure Plate
New Pilot Bearing
New Belt Tensioner
<U>Head (D16z6)</U>
3 angle Valve Job (done By local Shop)
Mildly Ported And Polished (only exhaust polished)
D17 Valve Springs & Retainers (A Little Stiffer Than D16)
Omnipower Flat Face Valves
Block Intake Manifold
Ls Throttle Body
BKR7e Plugs
Comp Cam/ Zex 59300
Skunk2 Adjustable Cam gear
Stock Injectors Fuel rail And FPR
Make Offer
New honda Oil Pump
New water Pump
New Timing belt
New NPR Rings
New Acl Bearings
Arp rod Bolts
z6 Rods
Arp Head Studs
GSR Thermostat
Stock Flywheel
New Pilot Bearing
New Belt Tensioner
<U>Head (D16z6)</U>
Ls Throttle Body
BKR7e Plugs
Comp Cam/ Zex 59300
