Car won't start during the day
Old Apr 18, 2008 | 01:41 PM
tambara's Avatar
Default Car won't start during the day
It is rather odd. During the day the engine will not start. It will turn but it won't turn on. Sometmies it will turn on but shut off after awhile. I am driving a honda del sol 94 si with a d16zc swap. I changed the starter, transmission, cap, spark plugs and distributor. Is there anything else I need to replace. This keeps happening.
Old Apr 18, 2008 | 02:13 PM
JDM3STAGEVTEC's Avatar
Default Re: Car won't start during the day (tambara)
so it starts at night???????
Old Apr 18, 2008 | 02:28 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: Car won't start during the day (JDM3STAGEVTEC)
undercover nightrider?
strange problem.
Old Apr 18, 2008 | 02:58 PM
tambara's Avatar
Default Re: Car won't start during the day (Dead CIVIC)
yea its crazy, i mean i would go to calc and when i come out it won't start. then once i get out of physics around 9pm it is ready to go and starts up. I am clueless. Like as of right now when i tried to go out to lunch it turns but it doesn't start. GAHHH someone help!!!
Old Apr 18, 2008 | 03:29 PM
MasterShake's Avatar
i doubt your car knows what time of day it is.....
check for spark and fuel, is the check engine light on???
Old Apr 18, 2008 | 03:33 PM
tambara's Avatar
Default Re: (MasterShake)
no i understnad that it doesn't know what time it is. I am telling you that it happens during that time. I have check all of those things. I changed the spark plugs. I even sent it to Honda
Old Apr 18, 2008 | 03:35 PM
what did they say?
Old Apr 18, 2008 | 04:21 PM
civic4life13's Avatar
* B A N N E D *
maybe in runs on moonpower instead of solarpower
Old Apr 18, 2008 | 04:30 PM
95jeremie's Avatar
Default Re: (civic4life13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4life13 &raquo;</TD></TR><TR><TD CLASS="quote">maybe in runs on moonpower instead of solarpower</TD></TR></TABLE>
sorry but that **** was funny
really what did they say?
Old Apr 18, 2008 | 11:18 PM
tambara's Avatar
all they basically said was that i needed a new starter. I got that replaced, but it still does the same thing.
tambara's Avatar
no check engine light
Old Apr 18, 2008 | 11:36 PM
tambara's Avatar
Default Re: (tambara)
i think im going to replace the ignition coil and igniter to see if that helps any. I don't think its a fuel pump problem, because once the car is running i am able to turn it on again; however, once it cools down it starts to become a problem.
Old Apr 19, 2008 | 01:57 AM
batallic's Avatar
if its hot durin the day its probably the main relay
Old Apr 19, 2008 | 05:51 AM
cre8ive's Avatar
Default Re: (batallic)
I had a pretty similar issue with my 91 Accord. It would not start after sitting in the sun on a warm day. It turned out to the be main relay as batallic suggests. Good Luck.
Old Apr 19, 2008 | 10:03 AM
tambara's Avatar
Default Re: (cre8ive)
thanks for your guys input. I sent the car off to honda and should have it at 430pm i got the coil and igniter replaced. if that doesn't work off to the main relay and fuel source.
Old Apr 20, 2008 | 12:51 PM
tambara's Avatar
yup it was the main relay thanks guys!
Old Apr 20, 2008 | 01:01 PM
mechanix619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tambara &raquo;</TD></TR><TR><TD CLASS="quote">I changed the starter, transmission, cap, spark plugs and distributor. </TD></TR></TABLE>
I am happy you got your car to run again. The biggest lesson to be learn here is that it is not a good idea to start throwing money at the car looking for the one part magical solution. With a little patience and a good explanation of the symptoms you will end up saving yourself a lot of frustration and money. As it stands right now you probably dumped a few hundred bucks into solving this problem when in reality is should only have cost you the price tag of the main relay.
TimelessLlama
Aug 20, 2015 06:40 AM
EGandDArida
Aug 24, 2009 02:34 PM
bmxbikes
22
Jul 4, 2007 07:23 PM
93h22a1vtec
Jun 3, 2006 07:47 AM
same ol' civic
Jun 5, 2005 07:29 AM
