transmission grind or clutch ?
Old Apr 18, 2008 | 01:13 PM
vargas's Avatar
Default transmission grind or clutch ?
Whenever im going slow in 1st and 2nd gear, there is a noticeable grind . When im going faster in 2nd the other gears , i dont hear anything , just in 1st and 2nd. Also , sometimes it hard to get out of reverse when in gear.
Could the grinding be the transmission or clutch? Thanks
Old Apr 18, 2008 | 03:31 PM
MasterShake's Avatar
how far up does your clutch engage on the pedal?
Old Apr 18, 2008 | 05:04 PM
bubblebrain's Avatar
Default Re: transmission grind or clutch ? (vargas)
the grinding sound you are hearing is probably like a fast and constant knock. i would say it is a bad input cluster shaft bearing on the clutch housing. that is why you are only hearing it 1-2 gear and not hearing it so much in the other ratios. there is more stress on that bearing in 1-2 gear because those speed gears are closest to that bearing. the farther away from that bearing, which is 3-5 gear, the less you will hear it since the other end of the cluster shaft is supported by another bearing.
Old Apr 18, 2008 | 05:35 PM
vargas's Avatar
Default Re: (MasterShake)
it dosent engage right away , its a little soft
Old Apr 18, 2008 | 05:45 PM
-JSpecEk*9-'s Avatar
Default Re: (vargas)
1. worn clutch
building boost
Jun 6, 2008 07:30 AM
SlowSOHC-T
May 16, 2007 04:13 AM
ActiveAero
Feb 6, 2007 08:33 AM
oinkus
Apr 19, 2005 05:06 PM
nd8ch
31
Jan 28, 2004 10:03 AM
