02 ( oxygen sensor ) pinout on the ECU OBD2a
Old Apr 18, 2008 | 12:44 PM
d16rice's Avatar
Default 02 ( oxygen sensor ) pinout on the ECU OBD2a
I need to know which pins on the ECU correspond to the secondary (after catalytic converter) o2 sensor.
This is for a 96-98 OBD2a Civic EX
A diagram would be most appreciated.
Old Apr 18, 2008 | 01:25 PM
Relic1's Avatar
no diagram, but there are the O2 wires and where they go.
O2 wire color(harness wire color) - end location
white(white/red) - D14
black(black/white or black/yellow) - 12V ignition
green(green/white) - D13
black(black/white) - A5
Old Apr 18, 2008 | 01:27 PM
d16rice's Avatar
Default Re: (Relic1)
And this is for the after cat sensor, not the one in the header, right?
Old Apr 18, 2008 | 01:49 PM
Relic1's Avatar
yes
the harness wire colors will tell you if it's correct.
Old Apr 18, 2008 | 02:03 PM
ifIexplode's Avatar
http://www.ek9.org/forum/attac...s.gif
CHA CHING!!!!
Old Apr 18, 2008 | 02:20 PM
d16rice's Avatar
Default Re: (ifIexplode)
cool, thans.
both of these should help.
the only thing, in the diagram, it mentions VX a few times, which was only produced as OBD1 model. Will this still work for OBD2 EX?
looks like the diagram is for OBD1...
Old Apr 18, 2008 | 02:27 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ek9.org/forum/attac...s.gif
CHA CHING!!!!</TD></TR></TABLE>
that's for OBD1.
OBD2a - http://www.b18c5eg.com/obd2a.jpg
Old Apr 18, 2008 | 02:28 PM
d16rice's Avatar
Default Re: (d16rice)
I think this is actually what I was looking for...
Now I just have to track down all the wires
Modified by d16rice at 5:43 PM 4/18/2008
Old Apr 18, 2008 | 02:31 PM
Relic1's Avatar
^^^ better
Old Apr 18, 2008 | 02:33 PM
ifIexplode's Avatar
ahh. I read it wrong, 12 hour days do have an effect on me. sorry.
Old Apr 18, 2008 | 02:45 PM
d16rice's Avatar
it's all good.
I appreciate any and all help I can get.
Looks like I found most of the wires...
Secondary
D13 – SHO2/SG
Secondary Heated o2, Sensor ground
Wire color: red/yellow (d16y7)
Wire color: green/black (d16y8)
D14 – SHO2S
Secondary Heated o2, Sensor-2
Wire color: white/red
A5 – S02SHTC
Second o2 Sensor Heater Control
Wire color: black/white
Just one left, I think it might be D11, but I'm not sure.
I know you said it goes to 12V ignition, but if possible, I'd juch rather hook it up to the ECU than to something else.
Modified by d16rice at 5:53 PM 4/18/2008
Old Apr 18, 2008 | 05:00 PM
d16rice's Avatar
Default Re: 02 ( oxygen sensor ) pinout on the ECU OBD2a (d16rice)
any more input?
Just want to make sure I get it right
Old Apr 18, 2008 | 06:28 PM
Relic1's Avatar
either of the IGPs will work. A11 or A24
Old Apr 18, 2008 | 06:47 PM
d16rice's Avatar
Ok, I'll be wiring it in tomorrow... I hope it works
Old Apr 20, 2008 | 07:46 AM
d16rice's Avatar
SUCCESS!!!!!!!!!!!!!
I finished rewiring it.
After sitting in the garage for 18months, having a 5-spd conversion, vtec conversion and a bunch of others stuff done to it, it fired up on the first try!!!!
No check engine lights yet or anything
I just have to get used to the light weight flywheel, short shifter and stiff engine mounts.
BlackCivicEX
29
Jan 21, 2011 07:19 AM
Ls1 FD3s
Aug 27, 2007 06:44 PM
dturbo
Jul 26, 2005 03:17 AM
Sherm
May 23, 2003 12:47 PM
Soled Out
Jan 6, 2003 04:24 PM
