Eagle rods won't clear the main girdle on DOHC ZC. I can't notch the girdle enough...
Old Apr 18, 2008 | 12:16 PM
I8ayellowcrayon's Avatar
Default Eagle rods won't clear the main girdle on DOHC ZC. I can't notch the girdle enough...
Has anyone successfully installed a set of Eagle H beam rods (with the new "2000" bolts) on an OBD0 DOHC ZC???
I notched the cylinder walls, no problems there. But I have installed a rod, and turned the crank and it hits the main girdle hardcore. The bolt is almost flush with the outside of the girdle when it hits. There isn't even 1/32" between the rod and the edge of the girdle...
There is no notching to this, all I can think to do would be to cut a damn hole in the girdle for the rod to clear, and weld up some sort of support thing OVER the hole to clear the rod.
BAAAAAHHHHHHH! Why can't people make a part that fits???
I'll try to get some pics on here later for more clarification...
bigddallas1993
Apr 24, 2008 08:32 PM
Seijuro Hiko
Jan 14, 2005 03:52 PM
Ronin Panda
Jun 1, 2003 02:02 PM
Ronin Panda
May 29, 2003 06:33 AM
