HONDATA INTAKE MANIFOLD GASKET
Old Apr 18, 2008 | 12:13 PM
ganjasnack's Avatar
Default HONDATA INTAKE MANIFOLD GASKET
hey i got a hondata intake manifold gasket and a skunk2 intake manifold when i put it on the studs for the manifold arent long enoug. Is there a extended stud for this you can get?
Old May 18, 2008 | 09:22 PM
prettylew's Avatar
Default Re: HONDATA INTAKE MANIFOLD GASKET (ganjasnack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ganjasnack &raquo;</TD></TR><TR><TD CLASS="quote">hey i got a hondata intake manifold gasket and a skunk2 intake manifold when i put it on the studs for the manifold arent long enoug. Is there a extended stud for this you can get?</TD></TR></TABLE>
kingmotorsports.com has them
Old May 19, 2008 | 12:53 AM
boost'd_crx's Avatar
i use the stock studs with no problem. its a bit short, but works and runs perfect.
Old May 19, 2008 | 08:11 AM
jomama's Avatar
you'll want to run some sort of thread lock so the bolts don't creep/run out on you or else you may be SOL^
Old May 19, 2008 | 08:43 AM
all-mtr-teg's Avatar
local autoparts store, get some longer bolts and double ended studs
blackccoupe
Jun 11, 2009 03:23 PM
PrecisionH23a
Sep 19, 2004 07:38 PM
ebp 99 si
Jan 30, 2004 02:41 PM
GIANT
Apr 22, 2003 11:12 AM
