EG cluster in a EF?
I have a real nice EG (1994) EX cluster and want to know if it will fit (nicely) into a 1991 civic Si? Is there a write up somewhere? I have searched and came up with nothing. As much info as possible please.
Thanks in advance!!
Thanks in advance!!
I'm sure it can be done..I wouldn't know how...but I want to see one, maybe I'll do it one day?I've seen 99-00 civic si cluster, got a GSR cluster in one of my REX
I don't remember what post, but I'm sure it was a post somewhere here in HT that was linked to the 99-00 SI cluster that's where I saw it and it had the write up...but sorry no help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR91X »</TD></TR><TR><TD CLASS="quote">I don't remember what post, but I'm sure it was a post somewhere here in HT that was linked to the 99-00 SI cluster that's where I saw it and it had the write up...but sorry no help
</TD></TR></TABLE>yea the pics are not available anymore which render the thread useless
i got the 99-00 si cluster in my sedan and it fits pretty nicely...
also on the EG, its shaped like a rectangle whereas on the EF,EK,DC is more rounded...
so even if you were to find a wiring diagram, i'm pretty sure it wouldn't fit right because you would have a gap at the top and its fat on the bottom...
but hey, try it and lets see the results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9yee »</TD></TR><TR><TD CLASS="quote">Nice, is that the jdm center console? I've been looking everywhere for that.</TD></TR></TABLE>
nope, the even more hard to find USDM audio console. meant for the factory EQ, but i put an Accord pocket in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eighty-Nyne »</TD></TR><TR><TD CLASS="quote">I think i'm the only person that actually prefers the EF cluster haha</TD></TR></TABLE> i think so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ktp1598 »</TD></TR><TR><TD CLASS="quote">Thanks for all the info. I didn't think to check the lean on the cluster. Will the 96+ civic non Si with tach clusters work like the Si cluster?</TD></TR></TABLE>
Yes, wiring and fit are the exact same. It looks like it may be time very soon to post my write up on the 96-00 Cluster swap into the 88-89 ad 90-91 EFs...here's a pic of the Si one in my '89 DX
I really need to take current pics that show it finished and my NEW cluster that has a clean speedo as opposed to this one I got screwed with on Ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR91X »</TD></TR><TR><TD CLASS="quote">I'm sure it can be done..I wouldn't know how...but I want to see one, maybe I'll do it one day?I've seen 99-00 civic si cluster, got a GSR cluster in one of my REX </TD></TR></TABLE>
I'll try to post a new one soon
Na, i do too....here's the EDM oem cluster
If i were to do an EK cluster, i would use the CTR model like the one i run in my 96 Civic hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety »</TD></TR><TR><TD CLASS="quote">until my cluster dies, i will rock it.
i heart my ef sedan, is your 99-00 Si cluster fully functional? how long did it take you?</TD></TR></TABLE>
yes fully functional... just make sure u wire up an electronic VSS for the speedo because the cable VSS found in EF's won't work with the newer EK/DC clusters...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">
Yes, wiring and fit are the exact same. It looks like it may be time very soon to post my write up on the 96-00 Cluster swap into the 88-89 ad 90-91 EFs...here's a pic of the Si one in my '89 DX </TD></TR></TABLE>
You should post it. Ever since i saw this thread im contemplating going to the junk yard and pulling a 99-00 Si cluster, that looks really good. Probably way better lighting than my stock cluster too.
I imagine the swaps pretty straight forward as long as you have the pinouts and the electronic speedo cable.
I know it impossible to fit a bigger cluster in the 88-89 cars cuz of there small bezel what would u do in that case swap out dashes or can the newer round cluster bezel fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad »</TD></TR><TR><TD CLASS="quote">I know it impossible to fit a bigger cluster in the 88-89 cars cuz of there small bezel what would u do in that case swap out dashes or can the newer round cluster bezel fit.</TD></TR></TABLE>
Mines an '89 so yes it's easy to do, just swap out the cluster hood to a 90-91. You'll need to swap out the hazard and dimmer switch as well.
3 options:
DC2 Integra
EK Civic
EF EDM SiR
The problem is to do the cooler looking DC2 or EK ones, you have to do a lot of wire swapping, and the mounting doesn't use 4 holes, it uses 1 or 2.
I went with the EF EDM SiR because it looks stock, is in US units (MPH), fits perfect, goes to 9000 rpm and 150 mph, and takes very little work
Modified by GI8U2racing at 7:35 AM 4/20/2008
DC2 Integra
EK Civic
EF EDM SiR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing »</TD></TR><TR><TD CLASS="quote">3 options:
DC2 Integra
EK Civic
EF EDM SiR
]</TD></TR></TABLE>
There is no such thing as a EDM Sir, it's called a VT model and can be found in both KM and Mph versions. It basically needs to have the gauges themselves taken out of the edm cluster and dropped into the usdm housing, and boom done the mods when used for 1990 and 1991 models
DC2 Integra
EK Civic
EF EDM SiR
]</TD></TR></TABLE>
looks sweet!(99-00 Si cluster)...got the GSR cluster in my Gray CRX which is still in storage/garaged
which I can't wait to bring out! but only reason I might want a EG cluster is because I'm soon going to go SOHC in my other REX (D16z6)this coming week or so-so that'll be nice
</TD></TR></TABLE>looks sweet!(99-00 Si cluster)...got the GSR cluster in my Gray CRX which is still in storage/garaged
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannycraq »</TD></TR><TR><TD CLASS="quote">im looking for the write up for the 99-00 si into an EF with updated pics. </TD></TR></TABLE>
http://faq.ef-honda.com/index....ng=en
For some reason the pictures are not loading, but thats the write up I followed a couple years ago for my install.
