Fuel gauge stuck on F, sending unit and gauge OK
Old Apr 18, 2008 | 04:48 AM
crex23's Avatar
Default Fuel gauge stuck on F, sending unit and gauge OK
I've got a 89 CRX DX and the fuel gauge is on F most of the time, no matter how much gas I have. Usually when I start it up, it will read correctly. Then it seems as the car warms up, the needle slowly rises to F and stays there.
I've tested both the fuel gauge and the sending unit according to the Helms manual and both tested okay. The wiring coming out of the sending unit and out the back of the cluster look fine, no breaks or anything. Should I completely pull up the carpet and check the full length of the wires? Any suggestions?
Old Apr 18, 2008 | 05:50 PM
I heart My EF Sedan's Avatar
Default Re: Fuel gauge stuck on F, sending unit and gauge OK (crex23)
the signal wire might not have a good enough contact with the PCB on the back of the cluster...
Old Apr 18, 2008 | 06:14 PM
Crx Jimmy's Avatar
the gauge could have gone bad , it did in my car they cost something like $30 new from honda
Old Apr 19, 2008 | 09:27 AM
Patty's Avatar
Mine does the same thing. I even checked all the grounds it says in the Helm but it doesn't help. Replacing the guage hard?
Old Apr 19, 2008 | 10:42 AM
VtecSyndrome's Avatar
Default Re: Fuel gauge stuck on F, sending unit and gauge OK (Patty)
my '91 Si I just finished building is doing this same thing though I figured it's the sending unit. I have not replaced it yet So I'll know soon and I'll post up if I fix it, I do know that even though the sending unit may have passed the helms diagnostic test it could still be bad. There is not much else that would cause the gauge to act that way if voltage is correct w/ no shorts or anything.
Replacing your sending unit will likely fix your problem.
Old Apr 19, 2008 | 06:48 PM
crex23's Avatar
Default Re: Fuel gauge stuck on F, sending unit and gauge OK (VtecSyndrome)
Well I know to test the gauge it says to short out the 2 pin connector and the needle should rise to F, which is what mine is doing. So apparently the gauge is still okay.
It looks like a new sending unit is only $36 from Majestic Honda, so I might just try that.
Old Jun 2, 2008 | 10:01 PM
tacorunner87's Avatar
ok on mine it reads empty but when i fill the tank it takes about 7 gals. think that could be sending unit?
Old Jan 21, 2009 | 11:26 AM
crexmonsterb18's Avatar
mine is acting a bit stranger... when i fill mine, it reads below empty. and when it gets to about half a tank it reads correctly from half to empty. any suggestions on what is wrong with mine? majestic honda doesn't carry the sending unit anymore.
Old Nov 10, 2009 | 03:45 PM
HongoRLS's Avatar
I have 89 htch si wit same prblm! goes up to F good but wen it gets dwn to half way thats my E! can't find da prblm chged sending unit 2 timz, chged cluster 2timz!!!
Old Jun 1, 2011 | 10:14 AM
spcrxracer's Avatar
bump
Old Oct 10, 2011 | 07:54 AM
spcrxracer's Avatar
mine is doing something similar.
bump for answers
Old Oct 11, 2011 | 10:52 AM
crex23's Avatar
Haha I forgot I made this thread! What it ended up being was the gauge after all. I replaced the sending unit, didn't do anything. So I bought a cluster from the marketplace and used the fuel/temp gauge in my cluster (so I could keep the true mileage). I had indiglo gauges a loooong time ago, and apparently bent the needle taking them off. Hope this helps yall.
Btw, my fuel gauge doesn't go completely to the top, but is very close, within a hair.
Old Jun 11, 2014 | 12:34 PM
Rob.'s Avatar
That's the sending unit. When full, the needle should slightly pass the F mark.
My fuel gauge always reads just below full mark after filling up,
and when the needle is below the empty mark, I still have 12 litres left.
It's annoying!
It's been like this since I've owned the CRX in 2006.
I went ahead and ordered a new sending unit fuel meter today.
Only 1 left in Canada and I got it ! lol
Part Number: 37800-SH3-003
http://torontohondaparts.com/PartsLi...cal&illid=9473
There are 2 types:
NS or Denso
Check your gauge cluster to see if it has the 'NS' marking on the bottom right.
** WILL REPORT BACK AFTER REPLACING.
Rob.
Dec 8, 2020 06:34 PM
raverx3m
Oct 19, 2013 11:08 AM
sa2ms7on
Apr 11, 2012 07:13 PM
SpEcIaLkOuPe
Apr 25, 2009 12:58 PM
Frozen E
Oct 8, 2004 09:55 AM
