CEL 74
Old Jul 11, 2002 | 06:52 PM
fbp_hatchy's Avatar
Default CEL 74
Recently I overhauled my exhaust system by putting on new headers, LS cat, and a SIR cat back. However, ever since I put the new system in, I am getting a CEL 74. I tried replacing the ignition wires and even though it cured my rough idle, the CEL 74 is still getting thrown. Do any of you have any suggestions as to what I should try replacing? (dist cap, etc)
Old Jul 11, 2002 | 07:15 PM
Quik Chris's Avatar
Default Re: CEL 74 (fbp_hatchy)
I had an issue w/ 74-71 before. Are you running an OBD-II ECU? That's when my would come on, then I tried using the Skunk2 OBD-I conversion harness and an XS Engineering P72 OBD-I ECU, and no more CEL 71-74--- which in case you don't know is a random misfire in Cylinder 4, and 3 for 73 and the others respectivly. You haven't done anything w/ your knock sensor, have you??
Old Jul 12, 2002 | 03:40 PM
fbp_hatchy's Avatar
Default Re: CEL 74 (Midori Shinkansen)
Knock sensor? What is that?
Old Jul 12, 2002 | 09:19 PM
t's Avatar
t
OBD1 ecu does not have those codes, that is why you have no more CEL
Old Jul 12, 2002 | 09:20 PM
t's Avatar
t
it could be fuel related, but I would try changing rotor and cap.
Old Jul 14, 2002 | 03:48 PM
fbp_hatchy's Avatar
Default Re: CEL 74 (t)
t ... thanks for the reply. I replaced the cap and rotor to no avail.
91efbluehatch
10
Dec 11, 2011 04:37 PM
1fstlude
Dec 10, 2011 06:24 AM
raCeRX_88
Nov 22, 2005 06:06 PM
draxxus07
Sep 29, 2005 09:49 AM
Cruzan77
Jun 13, 2005 07:53 PM
