Looking for a D.I.Y. for CAI
not to be rude or anything. but are you really serious about a diy for a cai?? its pretty simple.
remove stock cai system. replace with aftermarket cai. remember to plug in the sensors and hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC »</TD></TR><TR><TD CLASS="quote">
remove stock cai system. replace with aftermarket cai. remember to plug in the sensors and hoses.</TD></TR></TABLE>
i would imagine that it is NOT that simple for someone who probably has no prior experience with these new cars. and this isnt just some sticker application, a mod like this should be done correctly.
OP:
http://www.8thcivic.com/forums....html
OP:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC »</TD></TR><TR><TD CLASS="quote">not to be rude or anything. but are you really serious about a diy for a cai?? its pretty simple.
yeah i thouged it wasnt that big of a deal but then i started reading up on some other peoples progress and i heard you have to take off your bumper, take the driverside wheel off and cut a part of the wheelwell off or something and i just dont feel comfident enough to go ripping apart my air filtration syspem without a good guide i can follow, or else ill be stuck and not know what im doing. and especially how our engine's are so compact, it seems ill probibly have to take the battery and trey out too huh?
yes.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 »</TD></TR><TR><TD CLASS="quote">
http://www.8thcivic.com/forums....html</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knaira112387 »</TD></TR><TR><TD CLASS="quote">i dont like how the cai is near the fender maaaaaaaaaaan makes me kind of worry about doing that because i live in washington.. rains all year long.</TD></TR></TABLE>
Unless you drive through free standing water and submerge the air filter you should have nothing to worry about. It is possible to cause the same damage with even the stock induction system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC »</TD></TR><TR><TD CLASS="quote">it pretty much comes like common sense.
Like having to take off the front bumber, possibly a WHEEL, without f-ing up all of the sensors and electronics that most other cars don't even come close to possessing. and without any prior knowledge/some to show you how. not all of us have these luxuries.
That, and some of the manuals even tell you how do it. According to my mechanic, doing it by the book (Ingen's book) only takes 6 hours.... i'll shell out the $ for an hour of his time to do it right.
its not a 6hr job...i'd say it took 45min for me to do it on my car by myself skimming the instructions.
its not an easy job though, especially if you dont know what your doing. i have a friend that doesnt know much about cars that tried to do it and it took him and another guy 4-5hrs.
there are also people on this website that can build an engine piece by piece. I am not one of them.
i'm sure i'm not the only person in this situation, but to me more than 60 mins. = 6 hours = rather have someone do it who
a. is more knowledgeable (in the business for 14 years)
b. insures his work
c. has a reputation to uphold to his customers who span the entire eastern seaboard.
b. insures his work
At the same time, it would help if you get in there and do it yourself. The first mod I ever did to my civic was install a turbo......with no directions. Took me awhile, but I got it done.
[QUOTE=specv5150]At the same time, it would help if you get in there and do it yourself. QUOTE]
very very true. But i can't afford to f somthin up on a brand new whip, with my budget, with my student loans. If i didn't work 7 days a week i'd def. invite one of you local guys over and learn step-by-step...
-by-
-by-
If you can't help or say anything to help this dude, dont say anything at all. If its negative to the topic dont say anything at all this is why honda-tech is known for their immaturity. You go to RX7 Club or the Supra forums they all help eachother out.
ANYWAYS..
PM madmonkey on 8thcivic.com he has made his own DIY CAI
ANYWAYS..
back on topic guys.
I got a problem during the install.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 »</TD></TR><TR><TD CLASS="quote">lol oh man..
look closer homie
I found a DIY for an R18 but not a K20 so here goes
(from the link)
def NOT an R18</TD></TR></TABLE>
see the second longer hose from the top that you have to replace that plugs into the intake? Yeah... well I... uh... pulled... and pulled... and it broke the plastic thing that the end attaches to on the left. I already looked inside and it seems to have a piston wth a spring or something, but i turned the car on and no check engine light went on or anything and the car runs smooth. Any suggestions on what i should do? leave it? or purchace the broken part from honda and replace it?
look closer homie
(from the link)
[IMG]
[/IMG]
Modified by Blackknight103 at 11:11 AM 4/19/2008
[IMG]
[/IMG]
[IMG]
[/IMG]
Modified by Blackknight103 at 11:12 AM 4/19/2008
anyone know wtf this is for? It seems there is a piston or something, with a spring inside but when i turn the car on nothing is moving inside. The hoses attach right to the intake so it must have been feeding it direct air. but why?
Modified by Blackknight103 at 11:13 AM 4/19/2008
[/IMG] Modified by Blackknight103 at 11:11 AM 4/19/2008
[IMG]
[/IMG] [IMG]
[/IMG] Modified by Blackknight103 at 11:12 AM 4/19/2008
your right man. brand new 2008.... not worth leaving anything unfinished. I looked around and this peice looks practially easy to replace, just 1 large nut around the bottom and theres a clip that holds a hose to the top... maybe its something more, ill call honda...
i was driving it to work today and i noticed something wrong. at a red light, normally, my rpm's would stay around 1,000 or 1,200. today i stopped at a redlight and noticed the rps were down to 600 or so and i watched it and the rpms were bouncing from 400-600 every few seconds and it seemed like it was about to stall itself, and it just didnt seem right. Ill get the plastic thing replaced and hopefully my rps will rest once again around 1,000... if not then
