Rear disc swap ?
Old Apr 17, 2008 | 04:53 PM
trustkill's Avatar
Default Rear disc swap ?
Im installing rear discs on my 96 ek hatch....correct me if im wrong, the Ebrake cables from an eg with rear discs will work with my ek?
Old Apr 17, 2008 | 05:11 PM
96civic_hb's Avatar
Default Re: Rear disc swap ? (trustkill)
Depends on what cable they used? I know majority of people use the integra e-brake cable.
Old Apr 17, 2008 | 05:43 PM
greenej8's Avatar
Default Re: Rear disc swap ? (96civic_hb)
From what i've heard the eg and ek are not interchangable. You'll need to get either SI or Integra cables to bolt to you chasis.
Old Apr 18, 2008 | 06:20 AM
Sundown's Avatar
Default Re: Rear disc swap ? (greenej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenej8 &raquo;</TD></TR><TR><TD CLASS="quote">From what i've heard the eg and ek are not interchangable. You'll need to get either SI or Integra cables to bolt to you chasis. </TD></TR></TABLE>
They do work. Atleast the ones from the coupe do
Old Apr 18, 2008 | 08:39 AM
EL Vap133's Avatar
From experience, I have used 99-00 Si rear disc brakes and the e-brake cables are a perfect fit!
Old Apr 18, 2008 | 11:31 AM
Blk00EJ8's Avatar
Default Re: Rear disc swap ? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">From experience, I have used 99-00 Si rear disc brakes and the e-brake cables are a perfect fit! </TD></TR></TABLE>
As have I. Si cables are designed exactly for that chassis (obviously ).
Old Apr 18, 2008 | 12:15 PM
philosofy1's Avatar
OK, here's the thing, they are all the same.
92-00 civic and 94-01 integras w/rear disc brake share all the same (exc. 4dr).
speaking through experience, they all are the same lenth and bolt up the same way at the same points with the same bends in them.
gotta love Honda!
PatrickFrantz
May 27, 2008 11:03 PM
NathanMorris
Feb 9, 2008 11:59 PM
killacam661
Jul 22, 2007 09:38 PM
GapxGuy
Aug 12, 2004 08:07 AM
sampol999
Feb 29, 2004 11:01 PM
