bad master cylinder or brake booster?
Old Apr 17, 2008 | 03:38 PM
stevescivic's Avatar
Default bad master cylinder or brake booster?
my 91 civic sedan is experiencing something a bit weird that I am not 100% confident on diagnosing.
brake lines/pads are all in excellent condition. No leaks or abnormal wear.
Brake booster - no rust or fluid anywhere.
Brake fluid = new
First pedal press while driving for a while without using brakes = sinks to 3/4 of the floor and brake pressure seems spongy/weak. Pedal is really light and easy to push. Almost as if I have no braking pressure.
Let go of brake pedal and re-depress pedal = tonnes of braking pressure.
Is my m/c bad or my brake booster?
My experiences from past cars that I've owned would suggest m/c but someone here please give me some tips b/c I would hate to replace the m/c to only find out that it was really the brake booster.
Nowhere is pedal effort difficult to depress.
Thanks
Old Apr 17, 2008 | 03:40 PM
97grnrs's Avatar
Default Re: bad master cylinder or brake booster? (stevescivic)
usually master cyl.. may car is doin this now...
Old Apr 17, 2008 | 04:00 PM
Default Re: bad master cylinder or brake booster? (97grnrs)
lets hope that my stupid m/c isn't leaking fluid into my brake booster...
Old Apr 17, 2008 | 04:23 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Also make sure your calipers are able
to "float" in/out on the mounting pins..
Some of the strangest brake problems I have ever dealt with,
the caliper was stuck on the pins and not able to apply equal pressure.
Old Apr 17, 2008 | 05:04 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
my civic did that. i just replaced the mc and booster and upgraded to the da's stuff
hella stoppage now
Old Apr 17, 2008 | 05:13 PM
fun4door's Avatar
to me it sounds like air in your lines..., you did mention new brake fluid, were you able to bleed it good...
Old Apr 17, 2008 | 11:25 PM
Default Re: (fun4door)
fixed it. It was a bad m/c. Brake booster paint got eaten away but otherwise all is good.
Thanks
Old Apr 18, 2008 | 04:38 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevescivic from other thread that was created on same problem &raquo;</TD></TR><TR><TD CLASS="quote">Well so I posted a question earlier this evening asking about a bad m/c and brake booster.
Well I took a peek under the hood with a light and it was very obvious that the m/c was leaking. Sadly I didn't catch it in time and it ate away a lot of the paint on my brake booster and even part of my engine bay's paint
To make a long story short I half *** repainted my brake booster with some tremclad rust paint after thoroughly cleaning the brake booster with plenty of brake cleaner and sandpapered the rusted areas and rough paint edges.
In the process of repainting the brake booster I used a heat gun on the highest setting to make the paint dry faster and I was drying the spot with concentrated heat where the m/c would bolt up to. Well I know for a fact that the brake booster had some pretty intense heat on it and after about 3 - 5 minutes of heating it up I noticed that it started smoking!
I quickly stopped and tried blowing cooler air on it but it was obvious that some light smoke was coming out of the brake booster hole. My question is: Are there any "meltable" components behind the front cover of the brake booster or do you guys think it was the grease that was on the brake booster shaft that plugs into the m/c?
After smoking for like 2 minutes I decided to start the car and let the engine pull air through the brake booster hole (where the m/c bolts onto) in hopes that the vacuum draw will cool the internals of the booster off quickly.
There isn't any visible signs of burning of the shaft or the exterior of the booster but now I'm worried that I may have really melted something inside. I re-installed the m/c and bled the brake system and it seems like the brakes are working very well.
Judging by the exploded diagram of the brake booster it doesn't appear that there is really anything on the front end of the booster that could easily melt from a heat gun.
Can anyone shed some light on my little mishap?
Thanks
Old Apr 18, 2008 | 06:48 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: bad master cylinder or brake booster? (CRX Toad)
I guess you already know what the answer is. shakes head.....
Old Apr 18, 2008 | 02:39 PM
Default Re: bad master cylinder or brake booster? (mar778c)
yeah.... that blows that I smoked the booster. Brakes works great so I guess I wait and see if the brakes get harder and harder to press. Maybe I'll be lucky and won't have to change it out. I went to Honda today to ask how much a new one was.... $630 bucks! Looks like the local wreckers will be my new parts joint.
Old Apr 18, 2008 | 03:44 PM
mar778c's Avatar
Community Builder
Just go to your local autoparts store and get a re-man unit.
Old Apr 18, 2008 | 04:54 PM
boosted28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Just go to your local autoparts store and get a re-man unit.</TD></TR></TABLE>
Old Apr 14, 2014 | 10:12 AM
davidrican's Avatar
I wanted to know if my brake booster is going bad on my 93 civic my brakes lock up from time to time
Old Apr 14, 2014 | 02:23 PM
smilindave's Avatar
check all rubber lines as well. replace if external cracks.
Regards
Dave
slowesteg
Suspension & Brakes
Sep 4, 2012 08:24 PM
kelviiv
Jan 9, 2011 11:31 AM
Jap_Spec_Imports
Jan 5, 2008 05:32 PM
spender1326
Apr 6, 2004 03:28 PM
95GS-R
Jul 18, 2003 08:15 PM
