Want to buy tilt steering column from Si to upgrade my 92 VX
Old Apr 17, 2008 | 03:08 PM
Alan Schappert's Avatar
Default Want to buy tilt steering column from Si to upgrade my 92 VX
I want to replace the unadjustable steering column in my 92 VX with a tilt column from an Si. I also want to buy an Si factory cruise for the VX.
Old Apr 17, 2008 | 03:34 PM
95vxtealhatch's Avatar
Default Re: Want to buy tilt steering column from Si to upgrade my 92 VX (Alan Schappert)
If i were you id just put some washers under the steering collumn to space the steering wheel downwards. Thats what i did and it works good. Its not on the fly adjustable but it does work. You'll realize putting in and adjustable steering column is ALOT more work the you wanted to get into.
Oh btw this needs to go in the for sale section.
Old Apr 17, 2008 | 06:36 PM
sauceja's Avatar
Default Re: Want to buy tilt steering column from Si to upgrade my 92 VX (95vxtealhatch)
If you took half your column down to add washers then the only thing left is to disconnect it from the rack to swap for an adjustable one. I though about doing this as well but haven't bothered.
Maybe when I get a gsr r&p for the hatch.
swizz977
Jul 24, 2012 06:56 PM
jetpilot
Jan 13, 2004 07:09 PM
eddiecut
Sep 3, 2002 02:25 PM
