distributor leaking oil....help
Old Apr 17, 2008 | 11:58 AM
epicbeats's Avatar
Default distributor leaking oil....help
i have a 95 accord and its leaking from the distributor.ive changed the o ring but it still leaks.wat else can it be?need help asap
Old Apr 18, 2008 | 04:25 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: distributor leaking oil....help (epicbeats)
have you checked the valve cover gasket around the distributor? maybe it's leaking from there?
Is it leaking inside the distributor? If so, there is a internal seal you can replace. See the FAQ for a how-to.
Old Apr 18, 2008 | 03:26 PM
epicbeats's Avatar
Default Re: distributor leaking oil....help (TouringAccord)
the valve cover gasket i replaced.it seems like its coming from the where u put the distributor into the head but the oring was replaced.i even put sealant
Old Apr 21, 2008 | 08:35 AM
epicbeats's Avatar
bump
Old Apr 21, 2008 | 08:42 AM
BlUAc's Avatar
Default Re: (epicbeats)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
Is it leaking inside the distributor? If so, there is a internal seal you can replace. See the FAQ for a how-to.</TD></TR></TABLE> double check the valve cover it might have a kink
user 929730482
Dec 3, 2013 09:08 PM
sonson6
Mar 20, 2007 07:56 PM
Fat Chick Magnet
Nov 25, 2006 03:08 PM
Jimmy
May 29, 2003 10:55 PM
