timing belt pulley removal *pics inside*
Spray some nut buster "PB Blaster" on it and let it soak.
Then pull on the sprocket with your hand while tapping the sprocket with a hammer. You can also have a friend use a screwdriver or prybar in conjunction with you pulling on it and tapping it with a hammer.
That should work.
-kenji
That should work.
-kenji
That should work.
-kenji
That should work.
-kenji
thanks for your help
Just have a bro come over, and slap a flat-head in his hand. Man one yourself, and pry on opposite sides while pulling w/ your hand. It will come off, even though they can be bitches.
