When did the honda civics start adding a neutral safety switch?
And the models that do have a neutral safety switch, is it possible to remove the switch so that you can pushstart the car? Or is it possible to push start a car with a neutral safety switch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imzjustplayin »</TD></TR><TR><TD CLASS="quote">And the models that do have a neutral safety switch, is it possible to remove the switch so that you can pushstart the car? Or is it possible to push start a car with a neutral safety switch?</TD></TR></TABLE>
personally i find it the most annoying thing every put on a standard car you can simply remove the switch then cut the 2 wires and join them together to complete the circuit
Should be no problem push starting a car with a nuetral safety switch. The safety switch interrupts the starter curcuit.
Mike"IAMSLOW"Myers
Aug 8, 2007 01:30 AM
