no fan?
Old Apr 16, 2008 | 10:17 PM
JDM_is_overrated's Avatar
Default no fan?
pretty much the problem is that the fan to the rad would not turn on. i ckecked all the fuses and relays. when i turn the a/c on that fan dont turn on either.
any suggestions?
Old Apr 17, 2008 | 12:24 AM
BYAAH85's Avatar
Default Re: no fan? (JDM_is_overrated)
run the fans directly from the battery to see if they are bad or not. than go from there
Old Apr 17, 2008 | 12:54 AM
jentee's Avatar
HMMM MAYBE THE WIRE GONE BAD?
U CAN ALWAYS DO IT STR8 TO THE BATTERY LIKE WHAT HE SAID
AND ADD A ON AND OFF BUTTOM=] GHETTOOOO
I SEEN SOMEONE DID IT ON A CIVI HAHA.
Old Apr 17, 2008 | 02:58 AM
94rs94's Avatar
Default Re: no fan? (jentee)
Fan switch? Try and first running the fan like stated above. If it works, then it just might be the fan switch. If it doesnt, then it is time for a new fan.
Old May 9, 2008 | 01:33 PM
Default Re: no fan? (94rs94)
where is the fan switch?
Old May 9, 2008 | 01:45 PM
Creator's Avatar
I'm not sure but your's might have a temp sensor in the back of the block. It could be that too.
Old May 9, 2008 | 01:47 PM
JETSPD1477's Avatar
fan switch is on the cylinder head under the distributor. its the small sensor with one wire on it.
its a little unusual that the condenser fan doesn't turn on with A/C. are you sure the relays are ok?
Old May 9, 2008 | 05:58 PM
Default Re: (JETSPD1477)
yea the relays are fine, temp sensor is fine, fuses are fine, i checked both fans straight to the battery and they work, the only other thing i can think of is the wiring somewhere. the ac fan is supposed to come on every time i turn it on, right?
p.s. does anyone have picture of the fan switch?
Old May 12, 2008 | 11:41 AM
Default Re: (JDM_is_overrated)
wow i could never imagine this is where the problem is, the problem was my rad cap. it wouldnt hold pressure therefore the temp didnt go up and fan did not turn on. thanks to my bro's advice the problem was solved. two heads are better than one
Old May 14, 2008 | 09:45 PM
Creator's Avatar
I think I've heard of this b4 on another car. Thxs for posting the solution.
Old May 15, 2008 | 06:42 AM
jomama's Avatar
i'm having the same problems on my daily 96 gsr after i rebuilt the motor. if push the A/C button, the fan doesn't kick in. no cold air. fuses are fine. all the connections are fine. ... i did, however, notice a puncture/tear in one of the radiator hoses in the head (back left corner) where radiator fluid starting flowing out and vaporizing JUST this last week... after about a month of driving the damn thing. i'll fix that and hope it fixes the A/C since the radiator cap issue ^ above brings up the same sort of issues that a leak in the coolant system raises. Fudge, now i'm just thinking about fixing the darn thing and getting rid of it
Old May 19, 2008 | 07:56 AM
jomama's Avatar
up for more advice, please
jdragon1974
May 20, 2010 08:24 AM
zeb1117
Apr 3, 2010 09:33 PM
ngoldsmith1@gmail.com
10
Nov 27, 2008 01:04 PM
motormike40
Apr 5, 2007 08:23 AM
kai-chun
12
Sep 8, 2006 03:20 PM
