Question about 96-00 front bumper support, beam, and stiffeners...
So i am putting the front bumper support/beam along with the stiffeners because i am tired of the sagging of the bumper itself under the headlights. I have a few questions:
A. Is the bumper support/beam bolted or welded on from the factory?
B. Can i re-install the bumper stiffeners(which go directly under the headlights) without the bumper support/beam or do they attach to it? (Do the stiffeners attach to the bumper support or the chassis?)
Thanks guys, i do believe the bumper support is welded but not positive and my guess aswell is the stiffeners are attached to the bumper support but hopefully they are not.
I do not have any of these parts and i am trying to avoid buying un-necessary parts so any help knowledge would be great. thanks
The radiator support is welded on, but the bumper reinforcement bar that you are referring to is only bolted on. It was meant to be removed and replaced in the case of an accident.
The stiffeners you are referring to bolt onto the reinforcement bar.
NFM_Dm
May 18, 2005 09:46 AM
