01 GSR Considering OBD2 to OBD1 switch advantages?? Input?? Tech help??
Old Apr 16, 2008 | 04:53 PM
Wikidconsepshnz's Avatar
Default 01 GSR Considering OBD2 to OBD1 switch advantages?? Input?? Tech help??
What is the advantage of going OBD1 on my 01 Gsr? It is a ls vtec swap and has a skunk 2 intake manifold and throttle body, comptech header and short ram intake with an apexi cat back and an Edyn remote mount breather can with pcv. How hard is this conversion to do?? What parts do I need to do it?? Do I have to swicth the distributor or any sensors?? Do I need to unplug the stuff that the obd2 ecu reads that the obd1 ecu doesn't?? Which would be the best ECU to use?? Sorry for all the questions but I am new to Honda tuning and performance. Any help would be greatly appreciated.
Old Apr 18, 2008 | 01:58 AM
Default Re: 01 GSR Considering OBD2 to OBD1 switch advantages?? Input?? Tech help?? (Wikidconsepshnz)
bump
Old Apr 18, 2008 | 03:00 AM
Ketone's Avatar
It is a simple conversion to do. You will need an ecu from an obd1 vehicle, such as a p72 (from an obd1 gsr), or a p28 ecu. You will also need a conversion harness to convert from OBD11 B to OBD1. A Conversion harness and an ecu can be easily found on this site.
The advantage is you will be able to tune your car, but adjusting fuel and timing maps using Hondata or a similar system tuning system.
You will not need to remove any of the obd11 equipment. The obd1 computer will not check for those sensors.
Hope that answers some of your questions
Old Apr 18, 2008 | 04:15 AM
OH_1fstgsr's Avatar
Default Re: 01 GSR Considering OBD2 to OBD1 switch advantages?? Input?? Tech help?? (Ketone)
Wikidconsepshnz
With the amount of modifications you have I would strongly recommend it.
I have a 99 GSR that is now run by a '95 P72 ECU and a wiring harness from OBD2a>OBD1. I am running a Hondata S300 in the ECU. No sensors where changed.
Old Apr 18, 2008 | 11:06 AM
Default Re: 01 GSR Considering OBD2 to OBD1 switch advantages?? Input?? Tech help?? (OH_1fstgsr)
so all you do is unplug the ecu plug in the conversion harness and new ecu and thats it?? seems way to easy lol
Old Apr 18, 2008 | 11:07 AM
oh also will it pass emissions with obd1?
Old Apr 18, 2008 | 01:11 PM
Ketone's Avatar
No, you will need to put your stock ecu back in the car to pass emissions.
98_ssbp
Aug 25, 2010 06:28 AM
JDMlude3189
Apr 11, 2010 12:57 PM
2.2 teg
Oct 20, 2005 08:21 AM
1zach4
Jul 31, 2004 02:42 PM
greekspeed
Sep 25, 2003 03:15 PM
