question on running a garrett TC4305
Old Apr 16, 2008 | 04:09 PM
Ekb18c5_BR's Avatar
Default question on running a garrett TC4305
hey guys i need your opinion this ..
ok, im finishing my new built :
b18c5(itr) block gsr head
eagle h-beam rods
wiseco pistons(8:9-1)81mm
stock crank
golden eagle block guard
450cc
log manifold
3"dp
blox imf
etc...
on crome
ok now my question..
im using a garrett (TC4305 turbo) The compressor side has a 58mm wheel, 70 trim, .70 A/R, the exhaust side is 57mm wheel, 76 trim and a .82 A/R
http://i130.photobucket.com/al...5.jpg
if i change the exhaust side to a .48 a/r and wheel ,would it restrict me on the top end ???
it just seams that the .82 is too big
power goals at least 350whp and up @15psi???? don't know
what do you guys think?
Modified by Ekb18c5_BR at 5:28 PM 4/16/2008
Old Apr 16, 2008 | 04:12 PM
Schister66's Avatar
Man U FTW
With a nice engine build like the one you listed, i would get something else for the turbo. If i were you, i'd look into either a 57 trim, SC34 or GT3255e. Also, your injectors are too small for your goals. A set of 550s might get you there, but i'd opt for a set of 720cc injectors
Old Apr 16, 2008 | 04:22 PM
Ekb18c5_BR's Avatar
Default Re: (Schister66)
thanks for the advice bro..
but i forgot to mention one think i ran out of money haha..
it was so post to be a budget built , so im stuck with this turbo for now ....
so you do you think??
change the housing??
Old Apr 16, 2008 | 04:33 PM
chimmike's Avatar
Default Re: (Ekb18c5_BR)
I agree with changing out the turbo. I'd never even heard of that model, which tells me it's REALLY old.
Save up and pick up a good GT series turbo. IF you can't wait that long, a precision SC turbo would work as well.
Old Apr 16, 2008 | 04:38 PM
tegdude227's Avatar
i agree you can find t3t4 turbos in many sizes on here for cheap new they are only in the $500 and they will all get you to your goal and some
Old Apr 16, 2008 | 04:39 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">I agree with changing out the turbo. I'd never even heard of that model, which tells me it's REALLY old.
Save up and pick up a good GT series turbo. IF you can't wait that long, a precision SC turbo would work as well.</TD></TR></TABLE>
If he doesn't have the money for ANYTHING else, i dont think a GT series is in the budget I think you need to read before posting things
Also, for his power goals, there's really no reason to run a GT-R series unless its the GT28r. If anything, a used Garrett would do wonders for your setup and still not cost a ton.
Old Apr 16, 2008 | 04:46 PM
Ekb18c5_BR's Avatar
Default Re: (chimmike)
i know what you mean man ...
the turbo came out of a 7.3 L power-stroke (garrett international),is actually a t4 on compressor side, t3 on turbine side.
Old Apr 16, 2008 | 04:49 PM
Ekb18c5_BR's Avatar
exactly
now can some one answer my question please....??????
Modified by Ekb18c5_BR at 5:56 PM 4/16/2008
Old Apr 16, 2008 | 05:26 PM
Ekb18c5_BR's Avatar
oh the other question i have is that when i spoke to the guy wo sold me the pistons ,he told me the if i ran the head gasket that i have (cometic .072 )would put me to 8:9:1 cr. but i think that's using the stock with .030 .
does anybody know with a .072 what cr it would put me on????
thanks in advance..
Old Apr 16, 2008 | 05:47 PM
Schister66's Avatar
Man U FTW
If you search "Honda compression calculator" on Google, you can find a few really good ones that will let you input the headgasket thickness along with your piston, head and block combo to determine your static compression
Old Apr 16, 2008 | 06:30 PM
Ekb18c5_BR's Avatar
thanks bro...
what about the exhaust housing question???
.82 or 48???
Old Apr 17, 2008 | 03:47 AM
Ekb18c5_BR's Avatar
anybody????
bzyq2001
Mar 12, 2011 12:34 PM
ryguy2588
Dec 17, 2010 09:13 PM
precisionsc54
Apr 21, 2009 01:19 PM
integranator
Nov 6, 2007 02:07 PM
ludelvr
Sep 16, 2002 03:12 PM
